Different riding style forks = different characteristics?
Motivation is the key...
Bikes: Trek Series 3 3900
I was just thinking, what if i put a DJ fork and went to ride XC, would there be any difference? (and also the other way around)
Is there any difference between forks for different styles of riding?
Bikes: Hecklah
Well, a DJ fork will be heavier and is usually sprung a little heavier.(that can be fixed) If you buy a coil sprung fork with different springs, you can adj that. An air fork is even easier.
If you truly go "Dirt Jumping" with an XC fork, expect something to eventually break.
Food for thought:
I had tossed around the idea of getting an '08 Marz 4x WC when I had the red Komodo. It's a pretty light fork and still pretty stout. It's not a "DJ" specific fork and could break under severe abuse, but I have read reviews from people who have taken the thing DJ and Urban and it's held up nicely. It's still light enough to be XC'able w/o too much effort. The 20mm TA would be a nice addition. Last summer they were like $625 everywhere, but you can find them readily now for $390'ish.
Food for thought:
Old School Rad
Bikes: Blur LT
There would be no difference, all forks are the same. The fork makers just want you to spend more money.
Like a circus monkey on a stolen Harley......
Bikes: Hecklah
Stiffer.
Example:
Gold Label Jump series 2
Category: High End 32mm Street and Dirt Jumping
Travel: 80mm or 100mm
Wt. Lbs: 4.6
Wt. Grams: 2086.1
Spring: X-Firm Coil Spring
Steerer: 1 1/8th High-strength steel
Damping: FFD with rebound adjust
Adjustments: Rebound
Stanchions: 32mm Gold Al
Casting: One piece Reverse Arch (RA) Magnesium
Axle: 20mm Hex Lock Thru Axle
Crown: Hollow Aluminum
Lubrication: Semi Bath with Evil Genius Seals
Wheel Size: 26
Disc Mounts: Post
Disc Size Size: 210 Max
No Boss Option: Only
Ride Height (mm) : 460, 480
Color: Disco Gold
Notes: Grind bolt on spring leg
Basically enough to take the initial shock out of a biffed landing. It's all relative to rider weight of course. As I said above...preload is always adjustable...especially if you buy air. Rockshox coil forks are kinda pissin me off. The last I was aware, they don't have adjustable spring preload. "Change Spring".
Example:
Wt. Lbs: 4.6
Wt. Grams: 2086.1
Wheel Size: 26
Disc Mounts: Post
Color: Disco Gold
so it's mostly about the stiffness of the spring and the strength of the fork...rite?
but wouldn't air forks' valve blow?
use your best eye
Bikes: '75 Bertin, '93 Parkpre Team 925, '04 Kona King Kikapu, '05 Bianchi Vigorelli
Wasn't the deal with spring forks, that if you adjusted for rider weight by preloading or compressing the spring, that you also effectively reduce available travel? Change the spring itself and you keep the travel? I'm not that smart about forks, but that is what I've always understood.
"I tell you, We are here on earth to fart around, and don't let anybody tell you any different." - Kurt Vonnegut jr.
Bikes: Hecklah
No. The end of spring travel doesn't cause the bottom-out in the fork. There's something else in there that ends travel. I don't know if it's the push-rods or some bumper or what. I got 130mm of travel with my Fox 32 Vanilla whether the preload was maxed out or all the way off. It just made the spring firmer and more difficult to reach the end of travel with the same rider weight.
Official Website Waterboy
Bikes: a lot
****** (can I say this?)
Moar cowbell
Bikes: Bike list is not a resume. Nobody cares.
Quoted: 29 Post(s)
Liked 6 Times
Hey Ed-
RST Suspension | Canfield Bikes | 7iDP Protection | Maxxis | Renthal | Hayes | VonZipper Optics | GoPro
Originally Posted by Mark Twain
"Don't argue with stupid people; they will drag you down to their level and then beat you with experience."
