Crank set needs stress relief
Back In The Saddle
Bikes: N+1
Quoted: 87 Post(s)
Liked 8 Times
Saw this in the For Sale forum:
"Campy SR 170mm 53/42 rings. MUST BE STRESS RELIEVED. If you dont know what 'needs to be stress relieved' means do not buy and do not ask."
Ok, I'll admit I don't know what "stress relieved" means. Can someone kindly enlighten me?
Dan
Dan
In life there are no mistakes, only lessons. -Shin
Quoted: 2026 Post(s)
Liked 1,096 Times
This makes my "BS" meter read rather high.
Bikes: 3Rensho-Aerodynamics, Bernard Hinault Look - 1986 tour winner, Guerciotti, Various Klein's & Panasonic's
Quoted: 159 Post(s)
Liked 375 Times
I think it means " If you are looking for a usable crank then don't buy these".
Back In The Saddle
Bikes: N+1
Quoted: 87 Post(s)
Liked 8 Times
Ok, "BS" or not, what does it mean? I've never heard of stress relieving a crank or rings or whatever.
Real Men Ride Ordinaries
Quoted: 17 Post(s)
I don't think it means anything. You can stress relieve wheels, but thats because they have different parts held together under tension. Cranks don't. Obviously that the post is really some sort of covert spy transaction.
Let your bike be the tool
Bikes: '66 Raleigh Carlton, '70 Ron Cooper, '95 Bianchi CD'I, Zonal Frame with Xenon gruppo, Carbon Frame with Record Gruppo, Columbia Twosome, Terry Classic, Bianchi SX, Gravity SS/FG
Quoted: 338 Post(s)
Liked 314 Times
Campy cranks of that era are known to develop micro cracks where the crank attaches to the spider, a "stress crack". Folks keep the crack from running by grinding away the cracked area. I've never had to do this to my NR cranks so my description might be inaccurate. So the seller is sayin' the crankset has a crack in it...
Never try to teach a pig to sing...
Back In The Saddle
Bikes: N+1
Quoted: 87 Post(s)
Liked 8 Times
Boomer
Bikes: Diamondback Clarity II frame homebuilt.
Quoted: 16098 Post(s)
Liked 1,457 Times
All of my NR cranks had that little crank, back in the 70's. Get a 3/16 inch small rat-tail file and radius the little web aluminum where the arm joins the spider, then use emery paper on the file and polish up what you file, you will likely file that the crack is very shallow and disappears after the filing... FYI i never heard of the cranks breaking at this spot
Liked 1,096 Times
i ride a bicycle
Rumblefish
Bikes: 1973 Crescent Pepita Single Speed,1978 Raleigh Competition G.S.,1976 Raleigh Super Course MKII,1970's Motobecane Super Touring Fixed Gear, 1980's Denti Road Tech Five,Gary Fisher Hoo Koo E Koo,1973 Atala Giro,Cheap MTB Tandem,Schwinn World Sport
Why didn't you just ask the OP of the cranks, he seemed more than happy to explain.
Quoted: 38 Post(s)
Liked 11 Times
There are lots of ways to remove stress.It can be done with temperature,sound waves,shot peening,vibration.Depends on what kind of stress your trying to get rid of.If your trying to eliminate stress cracks,the best way is to shot peen.That will compact the metal and spread the stress over a larger area.
Liked 1,096 Times
Bikes: 2008 Novara Big Buzz
The difference between bead blasting and shot peening needs to be clarified in this thread.
https://www.speedwaymotors.com/METAL-...INET,2606.html
https://www.metalimprovement.com/shot_peening.php
OT, but a new one for me is laser peening:
https://www.metalimprovement.com/laserpeening.php
Bikes: Gilmour road, Curtlo road; both steel (of course)
Quoted: 273 Post(s)
Liked 10 Times
The laser technology is interesting; with the temperture component there might be a slight surface tempering effect as well as the mechanical effects.
Today, I believe my jurisdiction ends here...
