Range on an Izip with throttle alone?
It's easy being green.
Bikes: Trek Beach Cruiser, Sun X-2 AX (bent)
I've already searched tht forums, and I didn't find much. I've looked at the Izip ads, and they say range is 15-20 miles, pedal and weight contingent.
So I'm wondering how far one of these will go with just the throttle, which is an option. ...My ultimate quest is to throttle to work and then pedal home.
If you're referring to the SLA models (IZIP Trailz AL, IZIP Mountain Trailz, etc.) IZIP rates most at "Up to 25 miles with normal pedaling". This means you have to pedal to get the top range. From my experience, most riders get between 12-15 miles with throttle only. Keep in mind, you can add an extra battery pack to these models to double the range.
I also mentioned in another post that Currie (IZIP) is coming out with a new Li-Ion upgrade pack next year for their SLA bikes. This means you can convert your SLA battery to Li-Ion which will be much lighter weight, have an improved range (I believe it will be up to 30 miles) and about 3 times the life. Not sure about the price yet, but it will be an option soon...
