need info on 1984 motobecane gold
Hi and thanks for any help you can give me i think this is a 1984 motobecane other than that im lost could anyone give me the year if it isnt 1984 and the value it says marage sport thanks for your help.....
Avenir Equipped
Bikes: Chesini X-Uno, etc.....
That would be a Mirage. Look here to use the components to narrow the date down.
Mirages were lower end models, so value is probably in the $100-$175 range depending on condition, location, etc.
Bikes: 1982 Motobecane Mirage Sport, 1982 Motobecane Randonnee, 1978 Motobecane Grand Touring
The Mirage Sport (mine is a 1981) is an upgrade from the Mirage. It has the low end frame of the Mirage, but the seatpost, rims, stem, handlebars, etc., are aluminum instead of steel. Brakes are Weinmann sidepulls, all aluminum. The brake levers on mine are drilled as well. Considering that the frame is basically gas pipe, it's a pretty light bike. Mine weighs 24 lbs with a leather saddle, closer to 23 with the stock one.
Frame on your bike is likely 2040, "Inexternal" brazed (no lugs), and therefore should be the same weight as mine or lighter. Hope you enjoy your Moto as much as I do mine! Happy riding!
Thrifty Bill
Quoted: 1236 Post(s)
Liked 964 Times
+1 $150 +/-. Any decals on the frame as to its construction? No decals usually means high tension steel, which pushes value down. Any cromoly frame would push value up a bit.
If you look on the back side of components (like the derailleurs), you will find date codes. You can look them up on the link provided by Blankcrows above.
