I'm going metric...
Bikes: mountain bike, road bike
Quoted: 7 Post(s)
I'm going metric...
well maybe. No,not ride a metric (is that a double negative?). I am thinking about using the metric measurement system, like everyone else does except the USA. I'm not trying to change for global unity or any worth while cause. Actually, it is pretty petty and self-centered, going metric would make me use smaller numbers in my weight and bigger numbers in my rides
Have a great day and remember spring is right around the corner.
Downtown Spanky Brown
Bikes: Motobecane Phantom Cross Pro Kona Lana'I
You could allways go in stones and hands.
Clydesdales/Athenas, 14.2857143+ stones or 18+ Hands
Scan Me
Bikes: 2009 Trek 2.3, 2010 Specialized Secteur Sport
I've always thought stone was a great measurement for human weight. It helps you focus on a range rather than an increment. I personally want to be between 14 and 15 stone normally. It would allow me to not freak out about the minor fluctuations and focus on the general goal.
Bikes: 197x?? Raleigh rescued from scrap metal; Specialized Roubaix
Metric is good, better than SAE. But if everything is SAE around you, you have to adjust at least a bit.
Thread Killer
Bikes: Fuji Touring Xtracycle, Merlin Road, Bacchetta Giro 26 (Sold), Challenge Hurricane, Cruzbike Sofrider
Bikes: CAAD9-1, Windsor Cliff 29er
Metric is so much better than our system. As an engineer I frequently get frustrated that we are the last holdouts. The metric system makes so much more sense, you only have to remember one definition per unit (and some prefixes). If you know meters then you understand kilometers, centimeters, millimeters, and even micrometers. None of this feet, miles, yards, nautical miles, inches, etc. junk. Anyway, I feel I'm preaching to the choir. I've considered just quoting everything metric and forcing others to learn and interpret what I say, but that's kind of passive-aggressive.
Location: Beaufort, South Carolina, USA and surrounding islands.
Bikes: Cannondale R500, Motobecane Messenger
Quoted: 11 Post(s)
Not safe for work
How about make up your own system of weights and measures? Random stick, fill a sock with sand, invent microhexalogibutt, etc.
Decrepit Member
Bikes: 2003 Trek 520, 1996 Trek 370, 1996 Bianchi Osprey, too many others.
The metric system is overated IMO.
Australia went metric in bits and pieces from the early 70's to the late 80's, with most of the activity happening on the mid 70s. But I've never really converted.
I still think of my weight in stones . I'm 18 stone 6 pounds. That's 258 pounds for Americans and 117.5kg for everybody else.
I still work out my car's fuel consumption in mpg. That is to say I take the kilometres and litres, divide the by litres by the kms and multiply by 100 to get L/100kms, and divide that number into 282.4 to get mpg. You would use a different factor in the US because Australia always used real Imperial gallons, not the teensy-weensy Americanised gallons.
The badge on the side of my car says it has a 5.0 litre engine. But I know it's got 302 cubic inches. The metric wannabees couldn't even get the conversion right, it's more like 4.9 litres than 5.0.
I can tell you my bike is 21". I don't know what that is in millimetres. I would have to multiply that by 25.4 to find out, and I can't be arsed.
I'm 5'10. I know that's 178cm because I've had to work it out so many times over the years and it's stuck in my memory. Feet and inches are for real men. Centimetres are for girly men.
A couple of the kids in my office had a laugh the other day when I asked one of them to go out and get a pint of milk. That doesn't bother me, because they are young and stupid. Apparently I should have asked him to go out and get a 600ml carton, for heaven's sake.
When I'm thinking distance I generally work in miles. If I go for a 30 mile ride that means something. A 50km ride could be a walk to the bathroom for all I care.
And when I shuffle off this mortal coil, they'll be burying me 6 feet under, not 1.8288 metres.
Quoted: 11 Post(s)
One argument to switching over to metric in the USA was signage on highways. South Carolina would go bankrupt just replacing all the signs on the interstate highways alone.
Freewheelin' Fred
Bikes: Surly Cross Check
I use metric on my GPS because it makes my rides sound longer. 14.5km just sounds better than 9 miles. It's not so great for weight tho, takes a lot longer time to lose a kg than a pound.
Bikes: TREK 1400, Schwinn Criss-cross and Iron Horse Warrior
I have been home from Italy for over a year now and just made the change from metric. I simply thought 30 kilometers per hour sounded better that 18.64 MPH.
The Improbable Bulk
Bikes: Many
Quoted: 5 Post(s)
Liked 7 Times
Of course, I guess in imperial weight, we could resort to ounces, but grams are even easier to lose than ounces.
