Troubles with Kool Stop Supra 2 install
Old 01-25-09 | 11:59 AM
Hasek's Avatar
Bikes: 1997 or 6 Giant Rincon, 2015 Surly LHT, 1999 Schwinn Peloton.
I got a set of Kool Stop Supra 2's for my Tektro cantilever brakes. I can't seem to get them set up properly. With the threaded stud from the pad at the lowest point on the Tektro brake mount slot (brake arm), the pads touch the rim barely below the tire. I measured the pads I am replacing and it was a 4mm spacing. I initially set up the Kool Stops at 4mm, according to the diagram below. I then also tried the 3mm and 5mm which neither worked.
What I do believe the problem is that the 3 or 5mm spacers don't slide down below the "special anti-slip base" shown in the diagram. This base essentially puts another 1/4 inch of space in.
Any help would be greatly appreciated.
File Type: jpg
Hasek is offline
Reply
Old 01-25-09 | 01:26 PM
frankenmike's Avatar
mechanically sound
Bikes: Indy Fab steel deluxe, Aventon cordoba, S-works stumpy fsr, Masi vincere, Dahon mu uno, Outcast 29 commuter
Hmmm... I would probably use some ingenuity and either file off the anti-slip ridges or enlarge the hole in the conical washers.
frankenmike is offline
Reply
Old 01-25-09 | 06:47 PM
Hasek's Avatar
I was pondering doing that, but I was hoping I was missing something before I went and modified a set of $14 pads.
Hasek is offline
Reply
Old 01-26-09 | 12:57 PM
Gonzo Bob's Avatar
cycles per second
20 Anniversary
Bikes: Early 1980's Ishiwata 022 steel sport/touring, 1986 Vitus 979, 1988 DiamondBack Apex, 1997 Softride PowerWing 700, 2001 Trek OCLV 110
I put Kool Stop Supra 2's on my U-brake a few years ago and I don't recall any issues getting the spacers to fit on the threaded post.
Gonzo Bob is offline
Reply
Old 01-26-09 | 01:19 PM
TimJ's Avatar
15 Anniversary
Pics maybe? I'm having trouble visualizing the problem.
Lemond Zurich, Cinelli Hobootleg Geo, ICan gravel bike, Tifosi Rostra, Specialized vado turbo
TimJ is offline
Reply
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
