Converting to drop bars
I'm going to convert to drop bars on my Jamis Coda Elite, which has disk brakes. The stem on the bike is for handlebars that are 25.4. I was wondering if I should go with a different stem and go to the 31.8 handlebars. I have big hands and I thought that the bigger bars may be better. The photos are to show the brake cables and if I would have a problem with where the bosses are. I read where some people have had some problems with the Tectro (spelling) brake levers and I was thinking about going with Shimano. It will have bar-end shifters as well. Thanks for any help.
George
George
Quoted: 1572 Post(s)
Liked 643 Times
Doesn't matter. The 31.8 mm is only on the center clamp section. It doesn't apply where you put your hands.
Thanks Retro, do you think the cables would be a problem?
George
George
Real Men Ride Ordinaries
Quoted: 17 Post(s)
Cable routing can sometimes be a little finicky when converting to drop handlebars, but I think your cable stops on the downtube should present no problem.
Brake cables, on the other hand,, especially with disk brakes, you might want to get some stick on cable guides for the fork. It's always a little messy when you use zip ties, and it can even interfere with braking.
Thanks fuss, I didn't know they made them. I have tie wraps on it now and that will help clean it up.
George
George
Liked 643 Times
I wouldn't think so. Your cable housings won't be the same length but I don't know if they'll need to be longer or shorter. I get the handlebar how I want it and then make sure I can turn it all the way to determine how short I can cut the housing. A little too long is better than a little too short but way too long looks goofy.
Thanks again, I wasn't going to use the old cables. I was more concerned about the bosses, but I think everything is going to workout.
George
George
I'm having a problem finding handlebars with the 25.4 diameter. I find them with 26.0, but then I would need a clamp right?
George
George
25.4mm drop bars are out there:
https://www.universalcycles.com/shopp...p?category=635
There are many more options for 26.0 or 31.8 though so if you can't find what you want in 25.4, you will need a new stem. Luckily, you can find very cheap threadless stems in almost any configuration desirable.
https://www.jensonusa.com/store/produ...Handlebar.aspx
George
George
Quoted: 17 Post(s)
It might as well be raised now, but do you know if your disk brakes are long or short pull?
If you have long pull disk brakes your going to need a set of specialized levers, Dia-Compe, Cane Creek and Tektro all make them.
I hope these work.
https://www.jensonusa.com/store/produ...evel+R400.aspx
George
George
Gear Hub fan
Bikes: Civia Hyland Rohloff, Swobo Dixon, Colnago, Univega
I hope these work.
I suggest that you go with one of the already mentioned brands of drop bar brake levers specifically intended for V brakes and/or mechanical disc brakes.
Decrepit Member
Bikes: 2003 Trek 520, 1996 Trek 370, 1996 Bianchi Osprey, too many others.
I have just converted a bike to drop bars. I found the existing brake cables were too short. The cables exit the brake levers from the top and have to loop backwards and down, whereas flat bar brake levers exit horizontally.
If you have to get long pull drop bar levers look at the Tektro RL-520. These are basically the same lever as the Cane Creek equivalent and substantially less exensive. Both are higher quality than the original Dia Compe version.
Thanks a lot everybody. I'll call tomorrow and get the Tektro RL-520. You guys have been a great help and think this job will go pretty good.
George
George
Liked 643 Times
While you're shopping put some "compressionless brake cable housing" on your list. It'll make a big difference in the performance of your disc brakes.
headtube.
You'll probably have to change the stem anyway -- when going from flat bars to drops you need the stem to have more rise and less reach. Which, hmm, that's already a lot of rise and not much reach on your setup, especially if you ride the lower half of the trekking bars (which it seems, as all your controls are there).
Decrepit Member
I should have mentioned you'll probably be replacing the cables anyway. Most flat bar brake levers use a barrel shaped nipple versus the pear shaped ones on the drop bar brake levers.
George
George
I dont know if I have a problem or not, but will the Dura-ace shifters work with XT derailleurs.
Yes I do have some gel pads already, thanks.
George
George
Gear Hub fan
You should be fine if referring to current Dura Ace. Older 8 speed Dura Ace rear derailleurs were not compatible with other Shimano indexed groups. They used a different cable pull ratio.
