Modding a Sugino crank to accept a third chainring
Old 02-01-09, 04:40 PM
Liked 9 Times in 9 Posts
I've got a Sugino Mighty Competition crank I'd like to use as a triple. This is a 144 BCD NR clone.
Willow triple adapters don't seem to be available, and the TA ones are pretty spendy, considering that they are a wear item.
I'll do the TA as a last resort, but I've seen some examples of people getting cranks machined/drilled to accept a third chainring, wondering if anyone has done that and if so, a recommendation on where to get this sort of work done.
Local in the Washington, D.C. area would be nice if this were possible.
Thanks!
robatsu is offline
Old 02-01-09, 04:50 PM
Bikes: n, I would like n+1
Quoted: 127 Post(s)
Liked 133 Times in 108 Posts
Cranks like this?
https://www.schoellerfamily.org/bikes...s-20040808.jpg
There doesn't look to be a lot of material in there so I would not advise having them drilled and tapped. A machine shop should be able to do it but it might cost as much as getting a cheap triple crank and rings.
jccaclimber is offline
Old 02-01-09, 04:52 PM
Quoted: 1074 Post(s)
Liked 295 Times in 222 Posts
Originally Posted by robatsu
I've got a Sugino Mighty Competition crank I'd like to use as a triple. ..triple adapters don't seem to be available, and the TA ones are pretty spendy, ...I've seen some examples of people getting cranks machined/drilled to accept a third chainring, wondering if anyone has done that and if so, a recommendation on where to get this sort of work done.
Unless you find a machinist who's helpful to the point of being mental, bored out of his skull, or for some strange reason has decided to do bike work pro bono there's no way you're gonna get your part machined for a lesser amount than what buying a triple or the required parts would cost you.
dabac is offline
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
