Gear Indicator Options
Bikes: Stella
From no-tech to low-tech and beyond, here is what I have come across:
1. Captain has super memory and recalls exactly which chainring and which cassette or freewheel sprocket is in use at any time, thus knowing how many cogs are left to shift to if down-shifting or up-shifting is in order.
2. Captain is humble enough to ask stoker what combinations are in use, and stoker can at least see and say "there are two bigger sprockets left to use".
3. In-line indicators on the shift cables -- either the model aircraft collars with their mini-set screws, and stripes or other alignment devices on the downtube; or, the Shimano in-line tubes with the little red donuts on the cable that go back and forth as the cables move.
4. Tiagra ST-4500 brifters with visual indicators on the tops.
5. Campagnolo Ergo-brain, or Shimano Flight Deck, electronics.
Leaving aside any issues of brifter shifting systems (ShimaNO versus Campy versus SRAM etc.), has anyone used the Tiagras (for single or tandem bikes), and what was your impression?
And, other techniques (in addition to the "my legs tell me when to shift" answer) would be appreciated.
pan y agua
Quoted: 1447 Post(s)
Liked 724 Times
Captain tilts head down and looks under shoulder.
You could get lost and die.
You could hit a tree and die.
The considerable advantage of the Flight Deck system is that it offers virtual cadence calculated from the gear and the speed. This means that while you are coasting downhill, you can select a gear that provides a reasonable cadence, before beginning to pedal in earnest.
I added the Shimano in-line tube for the rear gears only, I can usally remember the chain ring.
Quoted: 1572 Post(s)
Liked 643 Times
I have one on my Klein too but on a single bike the greatest benefit may be that demonstrating the gear indicator "wows" people who don't bicycle.
Another gear indicator technique that you failed to list is simply using barcons or down tube shifters. After an orientation period just the position of the shifter will clue you into the gear selection.
Bikes: 1998 Co-Motion Co-Pilot, 2015 Calfee Tetra
Quoted: 177 Post(s)
Liked 6 Times
I tried the Dura Ace inline indicators on our bike but the little bead within the clear tube wouldn't stay put (the cable moved and the bead didn't). The idea is good but it didn't work for us.
Liked 5 Times
I use the DuraAce or XT shift indicators (10 vs 9) and highly recommend them. Don't grease the cable before you slide them on, though. I like them so much, I put a rear one on my single bike. Much cheaper than a Flight Deck, and just as much information. Looking back doesn't work with the stoker's leg in the way, for our geometry at least.
How about barcon shifters? The position of the shifter visually indicates what gear you're in. That and they are a LOT cheaper than brifters of any kind.
Duppie
Duppie
Bikes: Stella
I do appreciate the other comments, and will share that I've got two single bikes with venerable Suntour barends and one with traditional (well, they are indexed) downtube shifters. The tandem is the only bike with brifters, and since I ride it with others (whose single bikes are all brifter-equipped), swapping off captain/stoker roles, I don't want to change it from brifters. I'm interested in the visual indication just to make it a bit easier. Presently I've got the "collar" setup to show the front position and one of the XTRs on the rear cable. Ok, but the heads-up feature of seeing the chainring/cog at the brifter seems interesting.
Bikes: Bianchi xl boron, Trek WSD, Comotion Speedster, Giant TCR Advanced
As I home in on 70, I find that I can't always remember where I am anymore. I can't remember what gear I'm in either, so the flight deck on the tandem, while not perfect, gives me a heads up. Mostly I use it to verify that I'm in an "illegal" gear combo. to stoker-"Whats that noise?" looking at the flight deck "oh, I'm in THAT gear again"
Frank
Frank
just another gosling
Quoted: 3886 Post(s)
Liked 1,938 Times
Single is simple, but on tandem I really appreciate the Flight Deck. Screwing up the gear selection is a much bigger deal on the tandem. I find it helpful for it to seem like I know what I'm doing. I also don't like peering back on the tandem. Precious Cargo and all that. Even better would be a HUD in my glasses, but I guess we aren't quite there yet.
The Tiagras with gear indication work fine on our tandem. Compared to Ultegras, more throw is required on the outer lever to shift. Haven't had them long enough to comment on their durability.
Arsehole
I have a set of last year's Tiagras on my Marin road bike. They work perfectly well. As Abram mentioned, the throw is a little longer than Ultegra/DA, but they're also less expensive. I haven't had any durability issues yet, but they only have about 1500-2000 miles on them. Still, I haven't seen many come in the shop broken, either. Unlike the 105s.
Likes to Ride Far
My wife and I have Shimano in-line gear indicators for the rear shifter on every one of our single bikes and the tandem. Once installed (it can be tricky threading the cable through it initially) they have always worked perfectly. I'm now thinking of using one for the front shifter on the tandem, also. This is a lot nicer than using a flight-deck computer because it allows you to choose which computer has the right functions for you (I prefer ones with an altimeter and gradient meter).
If the Tiagra's have a built-in indicator, then that also sounds like a great option - I find it amazing that no company is including this kind of functionality as standard on better-quality equipment (we are not all racer wannabe's, some of us just like riding and using high-performance, but functional equipment).
Bikes: Trek T200 plus enough others to fill a large shed
Re. non working gear indicators:
Tip #1 is to pull the end off the gear indicator to get the cable threaded. I had a merry 1/2h until I realised the end came off. Doh.
Tip #2 if the red indicator is loose then you could replace it with a rubber O-ring or similar. Wouldn't be as visible but may grip whatever cable you're using.
Tip #3 Don't buy the gear indicator. Most of your clubmates will have taken one off a bike at some stage and have one lying in the shed somewhere.
I use a rear gear indicator on the tandem - it helps us to select the right chainring at the bottom of a climb rather than having to change under load half way up. On the single bike it's unnecessary both because I can see and to an extent feel what gear I'm in, and also jump out of the saddle and push a bit if needed. On the tandem the jumping bit doesn't work for us yet - moving around needs to be a bit more considered.
