Sunrace Freewhweels to Maillard hub
Bikes: 1991 Tomassini Prestige 1973 Raliegh Supercourse, 1975 Panasonic Sport Deluxe, 1983 Fuji S-12, 1975 Motobecane Mirage, 1983 Motobecane Super Mirage 1999 Trek 930 1989 Trek 930 ,
Ok this is a retro- french question.
Will a 5 speed Sunrace freewheel go onto a Maillard/Atom hub (which currently has an Atom freeweel)?
Is the threading compatible?
Bikes: Grifter BSA 20
I like the Mailard hubs
they were on a lot of old Raleigh racers
Ive built one onto a 27" steel rim for my Elswick hopper single speeder.
I just screwed a standard thread 16tooth freewheel onto the hub
so the 5 speed sunrace will fit no problem
Quoted: 147 Post(s)
Liked 8 Times
I had one on an 80s Peugeot. Its a nicely executed design on paper but they're losers in practice. And its impossible to find parts for them and that was true even in the mid 90s when I bought mine. Ditch it and get yourself a modern hub. You won't regret it.
Great State of Varmint
Liked 15 Times
The answer to your question is: Yes. A standard 5-spd. freewheel should thread on with no problem. Be sure to grease the threads on the hub and freewheel. And be sure to have the correct freewheel-remover.
Even the French used standardized tpi on their rear hubs. Otherwise you may need a Mon Dieu! freewheel.
Real Men Ride Ordinaries
Quoted: 17 Post(s)
I think your talking about the Helicomatic, but Mailard made a host of ordinary freewheel hubs as well. The Helicomatic has it's fair share of problems, and I would advise not getting too attached to one. Mailard freewheel hubs on the other hand are awesome. I have a 700 series that spins better than most anything else I can find. Don't dismiss Mailard because of that one idea, after all, what company hasn't had their fair share of folly (Dyna Drive, Delta brakes...the list goes on)
Quoted: 443 Post(s)
Liked 27 Times
It's no problem as long as you don't have a French threaded hub. I've seen French threaded Maillard 700's on eBay. It's very difficult to find freewheels for them.
