Strange Drivetrain noise/ behavior
Waiting for his CX
Bikes: Jamis Satellite, Motobecane Fantom Cross UNO, Fuji Team singlespeed
Hey guys I have a puzzler. My drivetrain has been behaving very strangely. Whenever I put any kind of power down, there is this strange grinding noise which comes from the casette area. Also, periodically the chain will feel like it slips for about 1/4 of a chainring revolution. I replaced the chain, oiled, and adjusted the rear derailleur and the slipping is less prounouced, but the grinding and some slip is still present. It occurs on every chain ring and there doesnt look like any "shark fin" action on any of the rings. One thing I have noticed is the derailleur seems to not rotate as freely and will sometimes seem to get caught and rise up towards the chainstay slightly. It also isnt as effective at holding the chain on the right cog when backpedalling. The cage looks like it may be bent, and I am investigating a replacement now, but does this seem consistent with the symptoms?
Bikes: Giant XTC Team Custom XC bike, Nashbar tourer custom commuter
Could it be a problem with the ratchet mechanism in the freehub?
Waiting for his CX
This is definitely a possibility. I may have bent the axle at some point or another, there is a very slight "wobble" in the cassette if you freewheel quickly. The only thing is this phenomenon has existed for a while without the above issue, and the wobble may just be an illusion of the shift ramp pattern since its only perceptable at high rpm.
Quoted: 2026 Post(s)
Liked 1,095 Times
A new chain on a used cassette will frequently cause skipping.
Also, check the new chain for a tight link. Pedal backwards slowly and watch the chain as it exits the lower rd pulley. A tight link will cause a kink in the chain at that point that is obvious.
Waiting for his CX
Yeah, im familiar with this this, but the problem got a bit better with a new chain. Also, no tight links on the chain, and the skipping only occurs under moderately heavy pedaling/ accelerating.
