Shimano chain rings
Shimano chain rings
I have a Cannondale touring 2 and I want to switch out the smallest front chainring (26) and replace it with a 22 tooth ring to lower my uphill grinding gear. The current crankset is a Shimano 'FC-M443' which has a 64mm bcd. I have found a 9-speed compatible, 22 tooth Shimano 'XTR M960' chainring online, which has the same bcd (64mm) and I want to know whether I will find any compatibility issues between the chainring and the crankset? Is there anything else I need to look out for before I stump up the cash?
Thanks to anyone who can chime in and answer definitively
G
G
