Friel's LT test...didn't mess this up did I
So I just did my 30 min time trial and my average of the last 20 mins was 172
I believe Friel says this is not likely to change unless your very new to cycling/in poor shape or you did control your Variables properly
after this test I was pretty exhausted I do not feel I colud have held a faster pace.... took me a few mins to feel recovered and start to breath normally again
I did however shift gears and spin a high RPM (105-110) at time for me and other times a bit below 90 as I moved around my rear cassette
Shifting would not matter would it?
I also did not hold a paticular speed?
but I pushed like someone was on my rear wheel and I was trying to drop them for the whole 20 mins
Mountain Goat
Bikes: Cannondale Synapse 3 Carbon
Shifting and variations in speed don't matter as long as your perceived exertion remained the same. It seems like you did it right.
Mountain Goat
Do you mind if I ask how old you are? I was just going to post about this myself. I did this test three times recently. My LT came in as 173 twice and 172 once, so I think it is fairly accurate.
I am 41 years old, so by the various MHR calculations, my MHR is about 180. That means that my LT is 96% of MHR and that my LT is 92.1% of my VO2MAX. What I can't believe is that would put me in the "elite athlete" category. I am pretty good shape, but I don't think of myself as elite.
Climbing Above It All
MHR calculations are pretty much useless. I'm 51 and the max I've seen on the bike is 192. Running it's a few beats higher.
Mountain Goat
Londeree and Moeschberger (1982) 'Effect of age and other factors on HR max' - Research Quarterly for Exercise & Sport, 53(4), 297-304
Miller et al (1993) - 'Predicting max HR' - Medicine & Science in Sports & Exercise, 25(9), 1077-1081
Medicine & Science in Sports & Exercise 2007; 39(5):822-829
In the last two years of HRM data that I have, I have only gone above 180 BPM 6 times, and for brief moments. The highest was 186 (ok, I had a 276 and a 252, but I am throwing those away as static). I do tend to think my max is around 180.
Are you saying there is no correlation between LT and MaxHR for VO2MAX, or that MaxHR doesn't exist?
Mountain Goat
Ok, that I get, given the citations above tend to rely on averages and individuals can be outliers.
molasses in winter slow
Bikes: '06 Serotta Nove, '04 Mondonico Futura Leggero, '08 Haro Mary SS
ignore the various mhr calculations. those such as 220 - your age may be accurate for some, but incredibly inaccurate for others.
yes, but not much you can do about it, so don't overanalyze it.
max is max. if you've recorded 186 more than once, that's probably closer to your max, what you might call achievable max, but not your true max. it wouldn't be 180. true max is something you probably don't want to find out. that's a gun-to-your-head, have-the-paramedics-ready number. it's more relevant for training that you've tested several times for your LT and have come up with 173.
Mountain Goat
[COLOR=darkslategray]
In thinking more about it, I think the numbers are showing it a few beats high. In riding steady, I feel like I can go forever at 170, working hard, but no burn. By 176 I am getting noticeable lactate buildup in the legs and can tell that I am anaerobic. I perceive that I am slightly anaerobic at 173 as well, so my guess is that 170 is really a better number.
Somewhat variable and individual. I understand that, but there seems to be some real science supporting that individuals do have maximums and that the maximums decline with age, however not in a purely linear fashion.
Quoted: 1856 Post(s)
Liked 664 Times
My age is 55, so my conventional prediction is 165. Based on the second formula, my prediction is 172.6. Based on an LT test I did 18 months ago, my LT is around 162, and my max HR is at least 182 (we saw 182 on the instruments, since we were looking for my peak power. I don't know if I could have gone faster, only that at that time my max was at least 182. It should have been either 166 or around 174.
But I do not believe that there is no maximum HR for an individual. It appears to be the case that it's really hard to predict. If you really need to know it, it needs to be measured. I don't think I really need to know it, since I do know my LT heart rate.
Mountain Goat
I guess I don't need to know it and just need to assume it is higher than the formulas suggest. I was only concerned that I might have been working too close to it, but I think my LT tests were pretty accurate, so my max must be higher.
Quoted: 1186 Post(s)
Liked 289 Times
Regardless of what your MaxHR is and provided you don't have any known heart problems there should be no worries about working too close to you Max. Your body will naturally regulate your effort such that it will be impossible to work for any length of time close to your Max.
