Bianchi Pista stem, oven cleaner?
Bikes: A few BSO's.
Quoted: 164 Post(s)
Liked 55 Times
I got an old Pista stem that is a bit scratched and nasty. Does anyone know if I could do the oven cleaner procedure I have read about, remove the anodizing, the lettering and polish it?
I don't think the letters are etched, just under some clear or something. It's not going on a Pista.
If there deep nicks, your gonna have to sand. or fill them with body filler, but thats a little extreame for just a stem.
the barbarian
Bikes: Independent Fabrications Crown Jewel, Surly Steamroller(FG), Abici Podium (road)
uuuuuuggghhhh, I tried this, The oven cleaner may have worked a bit, but not enough. You will have to sand forever to get the bianchi etching out and there are so many different surfaces on the stem it is actually a huge undertaking. I recommend using a sandblaster, then using a metal polish, that will save you a lot of cramped hands.
Bikes: 1994 Proctor Townsend Reynolds 753, TT S3 True North, Kona Major Jake, Kona Honky Tonk, Marinoni Puima, Cannondale BBU
Everything being recommended or done to that stem in this thread is going to weaken the aluminium. Have a nice funeral.
Bikes: A few BSO's.
Quoted: 164 Post(s)
Liked 55 Times
R U serious? I think you would have to sand down the stem to almost nothing to make it dangerous. If anyone else feels that way I'd like to know cuz I'm gonna eazy off the thing.
You do know if you polish an AL stem its going to rust and will not stay bright. Also, if it has deep nicks it needs to be thrown away. Any imperfection in AL will cause it to fail at that point.
Bikes: 2014 Trek Domane 5.2, 1985 Pinarello Treviso, 1990 Gardin Shred, 2006 Bianchi San Jose
Quoted: 62 Post(s)
Liked 29 Times
Spraying on oven cleaner(I'm assuming it's got sodium hydroxide in it) on the outside of the stem won't hurt it enough to weaken it.
If you soak it in a lye solution on the stove, then yes, it'll dissolve away to nothing eventually.
I should think sanding the stem would work the best though it may be more work than you want to do.
But if a nice shiny threadless stem was all you wanted, why didn't you ask first?
Velo-orange.com
$35 Pick your size. 6 degree drop(or rise)
Quoted: 62 Post(s)
Liked 29 Times
Aluminum oxide, a white powdery coating. You'll see it only if you don't ride the bike very often and never clean it. I wouldn't worry about it.
You can buff an aluminum part to a bright shiny finish but if sanding the anodizing is too much work, forget about polishing it later.
Bikes: A few BSO's.
Quoted: 164 Post(s)
Liked 55 Times
Because I got the stem for next to nothing and sanding doesn't cost me anything. But thanks for the link to the Velo Orange stem. That looks really nice.
