9-speed BarCon shifter w/ Sram x.9
LBS Employee/Commuter
Bikes: 2007 Trek Soho, 2010 Gary Fisher Monona w/ Xtracycle FreeRadical, 198X Facet BioTour 2000
I converted my flat bar 1x9 into a drop bar single speed for the winter and like the feel a lot better. As spring arrives I've been longing for about 6 more gears so I want to put the 9 speed cassette back and derailleur on. I thought about using a mount extentsion and put my flat bat shifter on that. I think it would be ugly and cumbersome, though.
What BarCon shifter would work with a Sram x.9 9-speed RD?
Likes to Ride Far
Since I don't believe that SRAM make any 9-speed bar-end shifters, your best option is to go with a Shimano bar-end shifter, then use a Jtek shiftmate to make the cable pull correct for you SRAM X-9 rear derailleur.
However, the shiftmate is about US$40 and a bit of a hassle. For the same price you could get a Tiagra rear derailleur instead, and for a bit more than that you could get one of more comparable quality to your X-9 (and you could try to sell the X-9 to offset the cost).
Guest
Bikes: I never learned to ride a bike. It is my deepest shame.
Liked 6 Times
As above... might be a pain to get the X9 to shift with any available bar end shifters... I was looking at the friction-only bar end shifters available through rivbike.com (rivendell) and they claim the shifters will work with any available derailleurs except SRAM MTB style derailleurs- the ESP system requires more cable pull per shift so I assume the total amount of cable you have to pull to get to all the rear cogs is simply too great for available bar cons.
Swapping to a Shimano rear derailleur (or SRAM 10 speed or other derailleur that is compatible with available bar cons) is probably the easiest option.
I found some Ultegra BarCon shifters that are friction compatible for the right side. Would they be able to make this work? I know it is a different pull ratio between the two but I don't know which pulls more. If say a 10degree turn of the barcon pulls a Shimano RD 2 gears over, would a SRAM RD move 4 over or one?
Boomer
Bikes: Diamondback Clarity II frame homebuilt.
Quoted: 16098 Post(s)
Liked 1,457 Times
It is more likely that you will run out of shifter travel before you Move a SRAM ESP shifter through all of its range. Other than that, most if not all Shimano Barcons have an optional friction mode for the right/rear shifter.
Insane Bicycle Mechanic
Quoted: 788 Post(s)
Liked 688 Times
Jeff Wills
Jeff Wills
Real Men Ride Ordinaries
Quoted: 17 Post(s)
I've never actually seen one used for a shifter, but if they work for brakes, they ought to work for shifters.
I'm going to fabricate a 2:1/1:2 travel agent... Maybe. Debating this plus barcon purchase (can only find pairs, not right side only) versus putting the flat bar back on. Decisions... decisions...
