Tire question
Tire question
Old 01-26-02 | 10:24 PM
fubar5's Avatar
0^0
20 Anniversary
Bikes: Redline Monocog,Surly Crosscheck, Lemond Reno
Tire question
Is it a bad plan to mix and match tires? I only have 30 bucks and I need tubes also. Nashbar has some cool deals. I am looking at putting a Maxxis gluteus(rear specific) and a WTB velociraptor in the front..Is this a bad plan? Also, has anybody used nashbar tubes? Are they worth the money?
Booyah!!
fubar5 is offline
Reply
Old 01-26-02 | 11:39 PM
Dirtgrinder's Avatar
Dances with Rocks
20 Anniversary
I don't think it's a bad idea at all. It even makes sense to me that a rear tire would be different than a front. As you've noticed they make front and rear specific anyway. I haven't tried any Nashbar tubes, so I can't help you there. Good Luck Fubes!
If everything seems under control, you're just not going fast enough...
To become a registered member of BikeForums Click Here
Dirtgrinder is offline
Reply
Old 01-27-02 | 01:01 AM
pat5319's Avatar
20 Anniversary
Bikes: Seven Axiom Ti, Trek 620, Masi cylocross (steel). Masi Souleville 8spd, Fat Chance Mtn. (steel), Schwinn Triple Bar cruiser, Mazi Speciale Fix/single, Schwinn Typhoon
Ditto!
Ride Any Rubber
Pat
pat5319 is offline
Reply
Old 01-27-02 | 05:52 AM
20 Anniversary
Cycling on a budget, you grab any deal you can. I ride mixed tyres every day, with no ill effects. You may find one is a better stopper and the other a better go-er.
MichaelW is offline
Reply
Old 01-27-02 | 06:51 AM
toolfreak's Avatar
Ich bin ein Lowlander!
20 Anniversary
I ride mixed as well and if they`re non specific i switch rear and front depending on the surface.
They only thing you should notice is the rotation direction; really important !
Mark
Dancevalley 2th of august 2003 -> JXL, Laidback luke, Sasha, John Digweed, Monica Krusse.....and on!
toolfreak is offline
Reply
Old 01-27-02 | 08:33 AM
20 Anniversary
unless you are buying a lot of stuff, the postage will set you back more than the cost of a couple cheapos at the local bike shop. Chen Shin makes some decent tyres, cheap.
Je vais à vélo, donc je suis!
D*Alex is offline
Reply
Old 01-27-02 | 12:45 PM
Richard D's Avatar
Donating member
20 Anniversary
Any advantages to having a semi-slick rear and front slick, or vice-versa? could you minimise rolling resistance but still have some grip on gravel? I guess a slick front would work better?
How about different wheels?
Richard
Currently riding an MTB with a split personality - commuting, touring, riding for the sake of riding, on or off road :)
Richard D is offline
Reply
Old 01-27-02 | 06:25 PM
fubar5's Avatar
0^0
20 Anniversary
I'm just going to spend a little extra and get the WTB velciraptor front specific, and the the rear specific. That way my tires will match, and my tires will be from an American company, and I will be happy. coolio. Jsut one question..The front tires is a "velociraptor 44/50" tire..what doesn the 44/50 stand for?
Booyah!!
fubar5 is offline
Reply
Old 01-27-02 | 07:50 PM
fubar5's Avatar
0^0
20 Anniversary
Nevermind my question about 44/50 or whatever..That tire was a 1.9. The rear is a 2.1 and i want both tires to be the same size, so I spent a little more and got the front tire the same size...Plus it has a kevlar bead, coolio!
Booyah!!
fubar5 is offline
Reply
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
