Aluminum Frame ok?
Asker of silly questions
Bikes: '09 Cannondale Aluminum Synapse
Aluminum Frame ok?
Im 6'3" and 230 lbs. Is an aluminum frame ok to buy? Am I gonna crack that thing? I have my eye on this aluminum bike, but I dont want to buy it and break it. Should I just stick to good old steel?
Bikes: Cannondale Road Warrior
I just weighed myself this AM...225 lbs.
I ride an Aluminum Cannondale (Road Warrior Optimo frame). Aluminum will not be an issue. Make sure you have good wheels, though. Mine are stock 32 spoke (700 x 25C tire).
While I prefer steel for the ride qualities, I also own and ride an aluminum bike. I'm 220 and have never had a problem with any aluminim frame. The wheels will be the weak point here.
What bike are you looking at?
I am thinking of this bike:
https://www.bikesdirect.com/products/...corvus_al8.htm
I like the geometry and the components. The paint job sucks, but I have a friend who does powdercoat so I will get him to trick it up nice for me.
fishologist
Bikes: Diamondback MTB; Leader 736R
Aluminum...no problem, I am 310 and ride an aluminum roadbike. Regarding Bikes Direct, you may get quite a few differing opinions about dealing with them. If you do buy from them take the bike to the shop and have it put together.
We cannot solve problems with the same level of consciousness that created them. A.E.
1990 Diamond Back MTB
2007 Leader 736R
www.cohocyclist.blogspot.com
https://www.loopd.com/members/cohocyclist/Default.aspx
2007 Leader 736R
Unless it's a POS, you will not break ANY frame made of ANY material at your weight. I started at 6'3" and 230 on a Specialized Tarmac Expert.
Location: Beaufort, South Carolina, USA and surrounding islands.
Bikes: Cannondale R500, Motobecane Messenger
Quoted: 11 Post(s)
Frame material isn't nearly as important as wheel build quality. The wheels support the weight, not the frame.
The Improbable Bulk
Bikes: Many
Quoted: 5 Post(s)
Liked 7 Times
I weigh 350 and ride aluminum... It hasn't failed me yet...
Neither has steel...
I haven't had the nerve to try carbon yet.
Does anyone else have an opinion on this bike? Specifically the wheels?
Shimano makes good wheels--I know their top-end stuff is really good. The tires are low-end, cheapo stuff. Nothing to brag about, but they'll get the job done. Specs don't say what the hub is... might be the lowest model Shimano they make. Might be 105. Dunno.
Hard to tell, but looks like (from the photo) to be 20 spokes front and 24 rear. May be a little low for your size. Depending on what you're going to do with them, I would think at the least to go with 24/28. That said, I do have 24/28 Mavic Elite's... but I only use them for special events/races. My daily wheels are 32h, Mavic Open Pro's. I weigh in at 255-260 lbs.
Contact Bikes Direct. They try to keep a positive image, so they'll more'n likely give you the info you need, and maybe even swap out the wheels.
Quoted: 11 Post(s)
Bikes Direct has two Corvus Models, the Steel and the Aluminum. It looks to me like the Aluminum version has far better components. Is that an accurate judgement?
Here is the aluminum:
Here is the steel:
https://www.bikesdirect.com/products/...ier_corvus.htm
Here is the steel:
I weigh about 250, and while both my road bikes are steel, I've had a Cannondale aluminum mountain bike for 10 years. It's been ridden often and hard (I live a mile from a national forest), and it's had zero problems. Assuming you're talking about a name-brand bike and not some department store cheapie, I'm sure you'll be find.
S E Michigan
I started at 6ft 371 lbs and have never ridien anything but an aluminum bikes since I started back riding last Fathers day .... It a hold you just fine NO PROBLEM ....UNLESS its some cheap piece a crapola ....
Just remember, shopping at bikesdirect is a gamble - might be worth it though. They certainly do not pretend to care about the customers as soon as they have received the money. Try calling them? Good luck.
Aluminum should not be a problem; the wheels will likely not last very long.
Bikes: 3 good used ones
Quoted: 83 Post(s)
I agree with the wheel being the weak link. You will pop spokes long before you crack a frame.
Even if you get up out of the saddle, and crank down on the pedals, twisting that frame with the force of a dozen Lance Armstrongs, you aren't going to do dammage to the frame.
Bikezilla
Bikes: Co-Motion Mazama
I rode a stock Trek 7200 (alum) frame for 7,500 miles with no issues at 340#. Don't worry about the frame, worry about the spoke count/quality. That (and possibly the seatpost) is where your issues will occur.
Bikes: Lemond Chambery/Cannondale R-900/Trek 8000 MTB/Burley Duet tandem
Probably depends on the the design of the frame. I have an older 1998 Cannondale CAAD3 with oversized tubing at the bottom bracket area, no problems. MY 2005 Lemond ($1300) had smaller diameter tubing and flexed more thn the Cannondale.
After 13000 miles, the frame went "snap crackle pop" on a seated climb!..I rode it at 220-245 lbs for nearly 3 years.
Tilting with windmills
Bikes: Many
The only issue with bikes Direct is that you don't have a local shop when warranty issues and set up is needed. If you know someone who is familiar with light tune up work on a bike you can be set up and good to go in less than an hour. A good LBS shouldn't charge more than a tune up fee to put the bike together if you are not sure how to do it.
Most of the stories I have heard about warranty issues with BD see to work out in the end. I would not hesitate to order from them, but I have a Spectrum Cycles locally and it is the brick and mortar store front for BD. I would just go there and get my bike if I was looking at one of their bikes. Do web search for Spectrum Cycles. they have a few stores in different parts of the country. You might get lucky.
One thing other than wheels to consider is that the bottom brackets on BD bikes are very low end. It's a quick and easy, and not expensive, switch. I would highly recommend doing so down the road, but get all the miles you can out of the stock unit first.
Quoted: 11 Post(s)
I wouldn't worry too much over an FSA bottom bracket.
Bikes: 2008 Specialized Sequoia Elite
im 340# on aluminum and carbon with stock rims Alex AS1, 24-hole/28-hole so far nothing but good to say about them.2008 Specialized Sequoia Elite
Bikes: Kona Cinder Cone, Sun EZ-3 AX
Remember, aluminum has a better strength:weight ratio than steel...consider the number of aluminum airplanes you see compared to the number of steel airplanes...
Bikes: 2009 BMC SLX01/2016 Santa Cruz Bronson
Quoted: 8 Post(s)
I ride an aluminum CAAD9 and i'm at 275. I ride it hard and have had no problems. I've only put about 1600 miles since Dec. but it can handle more than i can dish out.
