shimano or SRAM chain
smitten by саша
Bikes: Salsa La Cruz with Rohloff; mutt parts
masterlinks are easier to work with for both installing and removing, but i really like shimano chains and the pin for reliability---it more closely acts like an original rivet, and in my own applications significantly reduces instances of chain suck and other chain problems. to be sure, the pins are more of a hassle than the masterlinks, but i don't really have need to take my chain on and off very often (and if it requires a serious cleaning, i just pony up the pocket change for a new pin).
Low car diet
Bikes: 2006 Windsor Dover w/105, 2007 GT Avalanche w/XT, 1995 Trek 820 setup for touring, 201? Yeah single-speed folder, 199? Huffy tandem.
I'm using a 10-speed Shimano chain and Wipperman Connex link on the road bike and a similar 9-speed setup on the MTB. My shop friend convinced me everything would work best using a Shimano chain with an otherwise full Shimano drivetrain, but I can't stand the replacement pin system.
Bikes: Trek 730 (quad), 720 & 830, Bike Friday NWT, Brompton M36R & M6R, Dahon HAT060 & HT060, ...
As a word of caution, the masterlinks deteriorate at least as quickly as any other links within a chain. By using them beyond the life of the original chain, you can speed up the deterioration of the chain within which you reuse them, and of the drivetrain.
I used to use Shimano now I use SRAM. The main reason for switching is I was having problems getting the Shimano pins in and out without bending the links. So I switched to SRAM and have not had any regrets. I like being able to take my chain off and they have been easy to work with.
In the end I think the Shimano might make for a stronger chain (if installed flawlessly) but SRAM is much more convenient. Also, SRAM makes it possible to use my new favorite lube.
Low car diet
Easy solution: Install it right-side-up. The Connex is shaped like a kidney bean. You know you have it installed correctly when the Connex's curvature matches the curvature of the chainrings and cogs.
