Stripped Derailleur hanger bolt.
٩๏̯͡๏)۶
Bikes: 2010 Giant Filter 1. 07/08 Apollo Independent.
As the title suggests, the bolt while holds my derailleur hanger to my frame is stripped; i.e. rounded off, so a hex wrench no longer can turn it.
The wrench slipped while I was tightening it, then continued to slip as I tried to un-do it to replace the bolt.
The bolt is tight, and will hold the hanger on fine, it's more the issue of needing to remove it if need be, for whatever reason.
So now, suggestions on how to remove and replace it, while minimising damage done to the frame?
Thanks,
Luke.
Thanks,
Luke.
Bikes: 2004 Trek 4600 SS, 2016 Cannondale Cujo 2 SS
Quoted: 13 Post(s)
There are screw extractors out there that you can chuck into a drill. Basically, it is a reverse threaded, tapered drill bit that digs into the metal of the screw and backs it out. How you would do it would be:
1. Get the proper size (not too big, not too small)
2. put into a drill
3. Reverse the drill so it would loosen a bolt
4. Push down relatively hard, and pull the trigger so the drill SLOWLY spins. If you go to fast, you will have the exctractor machine the head of the screw, rather than dig in.
2. put into a drill
Life is good
Bikes: 2018 Lynskey Helix Pro
Quoted: 522 Post(s)
Liked 10 Times
+1 on the screw extractor. They're available at any hardware store.
Quoted: 2026 Post(s)
Liked 1,096 Times
Try a brand new hex wrench of the correct size. Hex wrenches, particularly small ones, wear out and get rounded corners and then don't grip the bolt correctly. A new one with sharp corners may work.
A large, flat-bladed screwdriver may fit. Tap it in with a hammer. If it's a Craftsman, it will have a square shank and you can use an adjustable wrench to loosen the bolt. Otherwise, you can use a small pipe wrench or vice-grips on the shank, or pliers on the handle. If you use a screw extractor, you'll want to tap it in with a hammer first. Don't use a drill to loosen, just use an adjustable wrench on the square end (unless you have a tap handle, which is what it is made for).
٩๏̯͡๏)۶
I can't actually get vice grips onto the bolt. The bolt actually sits flat against the surface
We sell them at work, I'll pick up a set when I can
I needed a new set of hex wrenches, so I spent the extra dollars to buy a decent set over the weekend. The bolt is fairly rounded off, and that didn't work.
Thank you, and thanks to all others for your suggestions, I'll let you know how I go
Bikes: Gunnar Sport 105/UDi2, previous: Lambert, Giant FCR3, Cannondale Synapse Carbon 105, Specialized Roubaix SL4 Comp UDi2
Quoted: 29 Post(s)
Liked 18 Times
A six point socket will usually work on hex bolts or nuts, even ones that are severely rounded.
Liked 1,096 Times
Liked 1,096 Times
Quoted: 29 Post(s)
Liked 18 Times
Please forgive me. My '72 Lambert uses inch sized hex bolts; no allen heads at all.
Call me The Breeze
Don't touch it until you need to. Also, put the ezout into a tap handle, not a drill.
I make stuff up
Bikes: '85 Ritchey Commando, '96 Specialized Sirrus, '06 Surly Cross Check
Torx drivers also work well for engaging rounded out bolts.
Guest
Bikes: I never learned to ride a bike. It is my deepest shame.
Liked 6 Times
There was a company that used to make aluminum derailleur hanger replacement bolts - they were intended to be a break-away for use on frames that did not have a replaceable derailleur hanger. I mention this because I find it odd that the bolt on your derailleur stripped. I can think of three possible reasons why it happened:
1. Aluminum bolt and overtightened
2. Steel bolt corroded and completely seized into dropout threads
3. Wrong size allen key used (like you used an imperial size instead of the correct metric).
Of course none of this helps you get it out... as others have said, a large flat screwdrived put in place with a hammer could be the ticket.
Good luck!
Good luck!
٩๏̯͡๏)۶
I used the correct size allen key, a 5mm. Problem was that it was old and worn, and beginning to round off. It slipped once under a small amount of torque and that was the end of it. Any efforts to loosen resulted in further slipping and stripping.
Bikes: Canyon Ultimate CF, Moto LeChamp SL, Raleigh Rush Hour, Crescent MTB, Swedish Army issue bike
I'm having almost the exact same issue, though i think i can get the screw out one last time before it's completely rounded out. The question then,
Are the screws that attach the hanger to the frame standard? I'm looking for a screw fitting a fuji team sl; looks like a 8mm M4/5 or something close to that?
something like this, maybe: mcmaster link
٩๏̯͡๏)۶
This is the small bolt which attaches the hanger to the frame, not the derailleur to the hanger. It's similar to a chainring bolt.
This is my spare bolt..
