campy 9 speed ergo shifters with shimano 9 speed RD
Steel Member
Bikes: N + 1
Quoted: 7 Post(s)
Does this work? I'm asking because I happened to see this mix on a setup on someone's bike....and, a bike that's actually ridden at that. Not sure where I got the idea, but I was under the impression you couldn't mix campy & shimano on indexing....yes/no?
Campy 9 shifters pull too much cable and so do Campy 10 shifters. There is a method of attaching the shift cable to a Shimano RD that permits a 10 speed Campy shifter to be used with a Shimano 9 drivetrain. The better solution is just buy a J-tek shiftmate.
https://www.hubbub.com/articles_ergopower.html
Boomer
Bikes: Diamondback Clarity II frame homebuilt.
Quoted: 16098 Post(s)
Liked 1,457 Times
You might check the back issues of Velo News online. There were some articles by Leonard Zinn last summer about mix n match for Campy, SRAM and Shimano. Interesting stuff there.
Quoted: 2026 Post(s)
Liked 1,096 Times
A lot of the mix-and-match concepts work "sort of". They shift ok in the middle or at one end of the cassette but not all the way across. A J-tek makes the shifting work properly in every cog.
Boomer
Liked 1,457 Times
I ride this combo with a JTEC shiftmate. Perfect shifts every time.
Bikes: Bianchi, Miyata, Dahon, Rossin
Liked 5 Times
it works flawlessly once your cable stretches out and you have it dialled in properly.
Food for thought: if you aren't dead by 2050, you and your entire family will be within a few years from starvation. Now that is a cruel gift to leave for your offspring. ;)
https://sanfrancisco.ibtimes.com/arti...ger-photos.htm
Bikes: Cinelli Supercoursa 69, Ritchey Breakaway Cross, Mondonico Diamond Extra 05, Coors Light Greg Lemond (built by Scapin) 88, Scapin MTB, Stumpjumper 83, Specialized Stumpjumper M4, Lemond Poprad 2001
Quoted: 8 Post(s)
Liked 1,096 Times
What rear derailleur are you using, a Campy or a Shimano? I'm using Campy 10-speed Ergo brifters with a 9-speed Shimano cassette AND a Shimano rd and it shifts perfectly. But I use a J-tek with it.
Quoted: 128 Post(s)
Liked 12 Times
Here are the different options available for JTEK shiftmate. Find your combination of shifter/derailer/cassette and buy away.
https://jtekengineering.com/shiftmate.htm
"c" is not a unit that measures tire width
Liked 5 Times
one is the winter CX bike using a deore long cage with veloce 10sp shifters, and that didn't develop shifting problems until the chain was stretched to 1/8
