headset for 2008 Kona Kapu build
Old 03-24-09, 11:20 AM
fencerchica's Avatar
Bikes: 1982 Shogun
Hi, I've gathered thus far that while the '08 Kapu takes a 1" threadless headset, it's not a standard ISO 1" size but rather a JIS (Japan Industrial Standard) 1" size. However, I'm having a lot of trouble locating a specific model of threadless headset that comes in 1" JIS instead of ISO. Apparently when Kona chose the FSA Orbit X, they must have specced some kind of custom version of it, because I've read that the commercially available FSA Orbit X is an ISO 1" and won't fit the crown of an '08 Kapu without reaming.
Could someone suggest a specific make and model of headset to me, ideally with a retailler who carries it currently? Thanks so much.
fencerchica is offline
Old 03-24-09, 12:03 PM
cycles per second
Gonzo Bob's Avatar
Bikes: Early 1980's Ishiwata 022 steel sport/touring, 1986 Vitus 979, 1988 DiamondBack Apex, 1997 Softride PowerWing 700, 2001 Trek OCLV 110
Quoted: 44 Post(s)
Liked 71 Times in 48 Posts
This question came up a few years ago https://www.bikeforums.net/archive/in.../t-218054.html
and https://www.bikeforums.net/archive/in.../t-221412.html
At the time, Nashbar had a 1" JIS threadless headset (Aheadset I think) but it looks like they no longer do. Can you can mill your fork down and ream your head tube out for an ISO headset?
EDIT: Another possibility would be to install a 1" JIS threaded headset. Skip the keyed spacer and lock nut and just put on the threadless stem and top cap. You can probably pick up a 1" top cap at any bike shop if you don't already have one. You may need to ream out the threads on the top cup.
Gonzo Bob is offline
Old 03-24-09, 12:14 PM
Bikes: 1982 Shogun
I think that exceeds my current skillset as a home mechanic. But if I can't find someone who currently carries a JIS threadless, perhaps it'll be the only option. Is a milling/reaming job of this scope something that should be a routine job for any LBS?
Old 03-24-09, 01:27 PM
Bikes: 1982 Shogun
Ahhh! I think I heard a choir singing in the background as I found this:
Ritchey Logic 1" Threadless Black/Silver Headset 27.0 crown
$22.99 from www.racepacebicycles.com
Woohoo!!!
https://racepacebicycles.com/page.cfm...ils&sku=HD3224
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
