Do you have your lights on during daytime
Bikes: Dahon Speed TR and Dahon Speed Pro TT
Liked 5 Times
hi all,
when riding your bike during daytime, do you turn on your headlight and rear light ? blinking or steady ? do you also have lights on your helmet or anywhere else aside from front and rear ?
TIA,
vic
TIA,
vic
crazy bike girl
Bikes: '07 Orbea Onix, '07 Birdy Yellow, '06 Cannondale Bad Boy (stolen)
Depends on where I am riding.
If I am in the twisties, with no shoulder/bike lane and limited visibility (blind corners, shadows from trees, and/or fog) then I will often have my rear blinky on. I wouldn't bother with my headlight during the daytime though. I also try to make sure I am wearing something bright and/or reflective.
Countries I've ridden in: US, Canada, Ireland, UK, Germany, Netherlands, France, China, Singapore, Malaysia
States I've ridden in: Illinois, Connecticut, Massachusetts, Pennsylvania, California, Nevada, Missouri, Colorado
Bikes: xtracycle, electric recumbent, downtube folder and more
I use my lights in the blinking mode if I use them during the day. I always use them at dusk. The light in the sky is enough to keep the pupils small but the light near the ground is low enough to make it difficult to see detail and then add to that cagers don't see details well anyway.
cyclopath
Bikes: Surly Krampus, Surly Straggler, Pivot Mach 6, Bike Friday Tikit, Bike Friday Tandem, Santa Cruz Nomad
Liked 6 Times
I'll use my Planet Bike Superflash in the day - particularly if it's not super bright out. I also leave my dyno LED headlight on 24/7 since it never runs out of batteries and the light can't burn out.
I'm considering leaving them on as much as possible... I see too many bike incidents and if a day time running blinky can help, then I'll do it... although clueless drivers will hit you no matter what :/
These go to eleven
Bikes: BF Pocket Crusoe; B Tikit; dust-gathering MTB
Always blinking front LED, and for the rear, always blinking PBSF on helmet and blinking seat-post mounted light. At night the steady headlight comes out, and another taillight mounted to the far fender tip, usually solid mode.
As above post duly notes, lights and stuff won't save you; your riding style goes furthest towards that end, but lights never hurt. My wife laughs at me and thinks I look like an alien spaceship
Bikes: Surly Long Haul Trucker, Gary Fisher Hoo Koo E Koo, Dahon Mu P 24 , Ritchey Breakaway Cross, Rodriguez Tandem, Wheeler MTB
Quoted: 32 Post(s)
In Fog, yes I'll use both lights front and rear.
I... Don't care.
No, unless it's raining, foggy, or any other occurrence where visibility is reduced. Lights (one blinking, one steady, both front and rear) come on at dusk and stay on until I get home.
Bikes: '07 Brompton S6L; '10 Brompton M6R
I always use a flashing Cateye TL-LD600. If I'm going to be riding in heavy traffic, or it's raining, or just a bit dull, then I also use a flashing front LED - the one that came with my Brompton, not a make I've seen before, and not very bright. In the dark I also turn on the solid rear LED that came with the bike, and a Cateye HL-EL530.
I fitted Reelight SL100 front and rear blinkies to my 700c tourer, and use these in conjunction with a Cateye TL-LD1100 and the same Cateye HL-EL530 when it gets dark. (I bought a second mount, not a second light).
I have my front Trustfire 801 in S.O.S. mode on during the day and the the Superflash in blink mode in the back. The more visible you are to other drivers the better!
Membership Not Required
Bikes: Giant Excursion, Raleigh Sports, Raleigh R.S.W. Compact, Motobecane? and about 20 more! OMG
Quoted: 70 Post(s)
Liked 15 Times
I typically use the senso lights from B&M they take care of themselves. I do run a PB Superflash, usually on a seatpost mount. I will turn it on if the conditions warrant.
Aaron
Aaron
Webshots is bailing out, if you find any of my posts with corrupt picture files and want to see them corrected please let me know. :(
ISO: A late 1980's Giant Iguana MTB frameset (or complete bike) 23" Red with yellow graphics.
"Cycling should be a way of life, not a hobby.
RIDE, YOU FOOL, RIDE!"_Nicodemus
"Steel: nearly a thousand years of metallurgical development
Aluminum: barely a hundred
Which one would you rather have under your butt at 30mph?"_krazygluon
even since seeing a few cyclists with a front blinker, I did same.
I velcro a photon microlight on my brake levers and set it to medium flash.
Not to offend anyone, but the planet bike superflash is pretty much worthless in the daytime. At night it is minimally acceptable. I have the Dinotte 140 tailight on my Dahon D7, and this can be seen a half-mile away in the daytime.
Up close these cheap blinky lights look really cool and cute. But put yourself a hundred meters away and they are indistinguishable from the surroundings. A typical car can do 100 meters in 6 seconds. Subtract a few seconds for reaction time and you only leave them 2-3 seconds to safely merge into the passing lane.
If we want to be treated like vehicles, we need to look like vehicles. I don't get why people cringe at spending $100 for a taillight, when the same people gladly spend hundreds of dollars fixing their broken car lights.
I'm sure the Dinotte is as advertised but the $25 I spent on the Superflash was one my best $25 investments ever.
smallwheelsonly
Bikes: SmallWheelOnly
Yes I use DRL [Daylight Running Lights] when im riding the streets
blinking mode both front and back
during the day the front is angled 2~4 degrees to hit oncoming traffic[cars] right in the drivers eye. ..wake up... do you see me now !!
both lights are by Planet Bike 1 watt in blinking mode.
I use dual front lights at night on a high/low beam configuration continuous mode but sometimes one blinking to catch attention.
I have a reflective vest but I get too much attention from other people asking if im Security or If i work for City or Street Maintenance
Bikes: lots... even a Raleigh twenty !!!
I do agree with the thought that you get what you pay for. However, awhile ago I bought a Niterider light worth about $500au which had brilliant illumination...enough to melt bitumen at 2 miles, but when the globe died and I was quoted over $200 for a replacement.....I freaked out, so I bought a cheaper LED light ($60) and it works fine.
Some guys I know spend up to $1200 for lights, but that's for crazy MTB night sessions.
If I had generator lights, they'd be on all the time just because.
But the truth is, I put in most of my miles during the day and with battery lights I'd be wasting that many more batteries. I've never had an issue with visibility on a clear day. neverever. I'd be interested to hear from someone who did.
We have a tendency, as cyclists, to simultaneously overestimate and underestimate drivers. Remember that plenty of cars (although not all; daytime running lights are getting more popular) have no lights on during the day. Even without a huge amount of visual contrast, it's pretty easy for a driver to notice a moving object on the road if there's enough light around. I find that dusk is the most dangerous, when people often forget to turn on their headlights and haven't adjusted to the darkness yet. Right before sunset, especially, my light just seems to blend into the scenery.
747 Freight Pilot
Bikes: Rivendell, Bike-Friday Pocket-Rocket and one home made fixed gear
The only additional light that I have is a princeton tec "EOS" mounted to my helmet. Since I run dinottes on both front and rear, there really is no need for additional light. I know from what others tell me that my 140L in the rear is bright enough to overwhelm any other light that I would run, so it would be a waste. I do have a cateye TL600 affixed to the seat stay as a backup should the dinotte fail.
I do use an abundance of reflective material. I wear a reflective vest, reflective ankle bands, and I have reflective tape affixed to my helmet. In addition I have reflective tape affixed to my rear fender and in the winter I have tires with reflective sidewalls.
Liked 5 Times
surprisingly the comments varies. there is really no consistent pattern as far as lights are concern. but combining all the adivses, i'd say what i will do will be 2 headlights (1 steady and 1 blinking) and 2 rear (1 blinking and 1 steady) both daytime and nightime bike riding. will you say that this is the safest way ? and best combination ? oh by the way i may add another blinking by my helmet.
thanks all,
vic
thanks all,
vic
Female Member
Bikes: Citizen Tokyo (Silver), Schwinn Collegiate (1980's)
No, I normally don't have my lights on during the daytime but there are exceptions like if it's really overcast making it dark even during the daytime, or there are adverse weather conditions like fog, rain, snow, etc.
hipster traffic dodger
Bikes: IRO Mark V Pro, home made bamboo track bike, eddy merckx corsa extra, Airnimal Joey commute, UGADA Tikit
as soon as my dynamo-equipped Tikit with LED's comes in, you bet I will leave the lights on all the time!
I... Don't care.
thanks all,
vic
thanks all,
vic
multimodal commuter
Quoted: 1908 Post(s)
Liked 574 Times
