Custom designed dropouts
meech151
Bikes: MEECH road & cross bike
Want custom dropouts
Can anyone give me the name of someone who would cut a pair of custom designed steel dropouts? Thanks Meech
meech151
Can anyone give me the name of someone who would cut a pair of custom designed dropouts? Thanks Meech
I've recently been making my own drop-outs out of 3/16" 4130 cromoly using the drill press, bandsaw, grinder, and files. You need the right taps if you want fender/rack mounts or a derailleur hanger. A pair of simple front drops or track ends takes about an hour. More complicated rear drops with eyelets and derailleur hanger takes about two hours per pair.
If you wanted to send me a full-size drawing, I'd give it a go. You can PM me if you'd like.
Randomhead
Liked 3,696 Times
meech151
Thanks, let me get the design drawn up and you can see what it would take.
Framebuilder
Quoted: 8 Post(s)
Medici Mike
Bikes: Medici Pro-Strada, Medici Tandem, Wizard, Simonetti
Try paragon machine works they may have what you need already, don't know if they do custom work.
Randomhead
Liked 3,696 Times
what's the difference between this post and the last time you asked the question? Did nothing pan out from the other thread?
meech151
No, it panned out, I just wasn't familiar with the forum and apparently the thread didn't post immediately and I thought I forgot to submit it, then after rewriting it they both posted at the same time. Thanks
Randomhead
Liked 3,696 Times
definitely post pics of the bike when you build it
