Zipp 404 Valve Extender Noise
Atlanta Road Racer
Bikes: Specialized Tarmac SL3 will full carbon everything/everywhere and Zipp 404 tubulars for racing. Cyclocross bike is a 56cm carbon Blue CXc with carbon everywhere.
I am running Zipp 404 Tubulars for races, but I noticed that the valve extender creates a knocking/clicking noise as it moves inside the rim. Anyone come up with a good way to remove the noise? I was thinking of applying a little rubber cement to the valve extender to reduce the noise, but that sounds like a bad idea. Anyone come up with a more elegant fix?
Carpe Diem
Bikes: 2007 CAAD9; 2014 CAADX; PedalForce CG1
electrical tape around the valve extender.
"When you are chewing the bars at the business end of a 90 mile road race you really dont care what gear you have hanging from your bike so long as it works."
ΛΧΑ ΔΞ179 - 15% off your first Hammer Nutrition order!
i got nothing.
Bikes: 13 BH G6 with SRAM Red
if you can hear that during a race you are not working hard enough. just saying.
W.W.DZ.D?
Just Peddlin' Along
What bd says:
https://www.cyclingnews.com/photos/20...armacSL2_valve
Bikes: Scott CR-1 SL, Scott Plasma TT
Atlanta Road Racer
Unfortunately, I didn't use Zipp's carbon extenders which would have been quieter. I used metal Bontrager ones.... I'll go with some electrical tape at this point. Thanks!
Atlanta Road Racer
To the poster re: "not going fast enough"....no, I don't hear them in a race because I am going too fast. I race Cat 3's in the Southeast, and they are pretty fast down here. However, it is annoying to hear during warm-ups and pathetic to hear on $$$ race wheels.
Atlanta Road Racer
Northern California - moved to ATL 2 years ago. Fast guys there too. Different racing, more road races there, more crits here. There's a reason why Speedweek is here. GA, NC, SC are crit heavy areas....come try it sometime. The speeds at Athens Twilight are right up there with other parts of the US, I've seen races all over.
Bikes: confidential infromation that I don't even share with my wife
Quoted: 35 Post(s)
A short piece of electrical shrink tubing in a size a little larger than the valve extender's width. Put the tubing over the top of the extender and use a match to shrink the tube to make a molded fit over the extender. I have done something simular by using the shrink tubing over cable housing and shrunk it onto the casing where it touches the headtube.
Dirt-riding heretic
Bikes: Lynskey R230/Red, Blue Triad SL/Red, Cannondale Scalpel 3/X9
Quoted: 5 Post(s)
Liked 8 Times
The valve extender shouldn't be clicking around.
I had a clicking in my 404's that came from the QR skewer spring flicking against some part on the hub--I loosened the skewer spring's grip on the QR axle and it went away.
Personally, I can't wait to get a Zipp disc so I can bask in the "swarm of angry hornets" noise as I race.
"Unless he was racing there was no way he could match my speed."
Atlanta Road Racer
Thank you for the shrink tubing idea...genius.
Yes, it shouldn't be clicking....but it does....even to the pro's as noted in a prior comment....captured in this picture:
