Cateye double wireless max and av speed problems
Bikes: Marin Bobcat Trail
Hi guys,
I just got a Cateye Strada double wireless RD-400w and its great once I managed to get it working. Now every time I take computer of the mount once I parked the bike at work the Max Speed and Av speed goes to 0. While riding all the data comes through, cadence, speed, mileage max speed etc.
I have been pressing the button down in order to release it from the mount. Is this causing it to zero out? I had a wired model with cadence and the small clip that holds it in the mount broke because I did not press the button down, so I upgraded to this one. Can this data be reset, or whats going on. Its so annoying since it happens on every ride I remove the computer from the mount.
Thanks,
Leo
Thanks,
Leo
Quoted: 10 Post(s)
Don't press down -- that clears all of trip data.
You have to slide it out without any downward pressure. Not hard to do, once you get the hang of it.
The Strada computers don't have a button on the surface. It is on the back side, and the entire computer is hinged in the mount. This means that pressing down on the face pushes the button on the back (a clever design that is hard to explain in type).
When you push down, you are, in effect, clicking the button to go from time, max speed, average speed, etc., and if you push down for longer than a moment, you are telling the Strada to clear the data decks.
Hey slimagain,
That makes sense, a friend has the single wireless and thought that's how you dismount it. He doesn't park his bike outside so has no need to remove the Strada off the mount. So I guess I am the one clearing it ^_^. Thanks for the response, and hopefully that's all it is.
