Go Back  Bike Forums > Bike Forums > BMX
confused about the whole gearing thing...
BMX Dirt, vert, flatland or street? Drop in the BMX forum to talk to other 20" riders around the world. What is the best BMX bicycle for you? Learn all about it here.
Old 06-05-04, 02:37 AM
i notice most mid-high end bikes uses 39/14 gearing .....and some low ends 44/16
wut im tryin to ask is can i do 36/14 or something? would i need to do any modifications?
x3nonfuxion is offline
Old 06-05-04, 06:50 PM
~OPSEC~
Bikes: GT Timberline (mtb) and Haro Backtrail (bmx)
you can run whatever gearing you would like as long as the chain clears the frame....the difference is that with a shorter front sprocket you run less of a chance of mauling it doing stalls or grinds..good luck
PGZX3 is offline
Old 06-15-04, 07:40 PM
Dr. Evil
novice_101's Avatar
Bikes: trek vert 2, schwin oarnge crate
you shouldnt need to any thing as long as u found the right sprockets u should be able to just bolt em on and beware u will notice a big difference with the new gear ratio
novice_101 is offline
Old 06-15-04, 09:21 PM
~OPSEC~
not necessarily, if you go with a similar gear ratio there should be almost no difference in how the bike reponds to inputs....
a 25:9 comes out as a 55.6 in gear inches....
a 36:13 comes out to a 55.4 in gear inches...
a 44:16 comes out to a 55 in gear inches
and a 45:16 comes out to a 56.3 just for reference....
see, little to no difference to be honest....those sexy smaller gears are actually a harder drive, though small enough to be insignificant....but the gains in size and weight and placement are the real benefits...
PGZX3 is offline
Old 06-19-04, 06:46 AM
member of the year 2004
i dont really care about my gearing even though i am confused
dk_dude is offline
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
