Does this open clockwise or counter-clockwise? Picture inside.
I am taking apart bottom bracket on my bike and do not want to damage the thread.
So do I turn this CW or CCW? (My guess would be CW, but I need to make sure).
surly old man
Bikes: IRO Mark V, Karate Monkey half fat, Trek 620 IGH, Cannondale 26/24 MTB, Amp Research B3, and more.
Quoted: 46 Post(s)
Liked 42 Times
Hard to say. There have been different standards through the years in different countries of origin. What kind of bike is it, and what year?
But, it is most likely CW to loosen. If I had no idea which way to go with it, I would try that first.
jim
jim
Cross Check Nexus7, IRO Mark V, Trek 620 Nexus7, Karate Monkey half fat, IRO Model 19 fixed, Amp Research B3, Surly 1x1 half fat fixed, and more...
SB forever
SB forever
Guest
Posts: n/a
Quoted: Post(s)
Being that that is the drive side, it will most likely loosen over the top, counter clock wise. The other side will loosen clock wise, most likely. In most cases, pedals and bb's tighten over the top towards the front of the bike.
this unit come off clockwise.no , english is not equate to SAE in this case.
Read the stamped info. If it says 1.37 x 24, it's English and unscrews CW. If it say 36 x 24 it's Italian and unscrews CCW.
use your best eye
Bikes: '75 Bertin, '93 Parkpre Team 925, '04 Kona King Kikapu, '05 Bianchi Vigorelli
For the more knowledgeable here- what if it's French?
"I tell you, We are here on earth to fart around, and don't let anybody tell you any different." - Kurt Vonnegut jr.
OUTLAW BIKER
Bikes: Eddy Merckx team 7-11 Corsa Extra Full Dura Ace, 2015 Equalizer Electric Fat Tire Bike
Quoted: 5 Post(s)
Usually: left side left side threads... right side right side threads, right side lefty lucy
Quoted: 2026 Post(s)
Liked 1,096 Times
Your mom
If your bike is not Italian, that cup unscrews clockwise. And you're most likely going to need to honk on it. Try the Sheldon tool and a big breaker bar or pipe for more leverage.
surly old man
Quoted: 46 Post(s)
Liked 42 Times
Or, if it is French (sometimes), or even Spanish.
j
j
SB forever
SB forever
It's MY mountain
Bikes: Klein, Merckx, Trek
Quoted: 4337 Post(s)
Liked 2,980 Times
Italian BBs are threaded lefty loosey on the fixed cup but the threads themselves are a little different too - what do the markings say on there?
36 mm x 24 TPI = Italian
1.37 in x 24 TPI = English
The marking indeed says 36x24. The BB is made by Shimano but the frame is Italian (old steel Miche frame).
The reason why I asked is because I nearly turned cherry red trying to unscrew this and I was still not able to! It seems to be very, VERY tight!
Edit: I almost shat myself trying to unscrew it! It won't come off!
surly old man
Quoted: 46 Post(s)
Liked 42 Times
And when that fails, get thee to the Sheldon tool that (almost) never fails.
jim
jim
SB forever
SB forever
For loosening any stuck fastener, first make sure you have plenty of leverage. If you are using a 12" long tool, either find a longer tool or find an extension for it. For a stuck bottom bracket, I'd go for at least 24" if not more. Second, make sure you can hold the tool stable while you really crank on it. This may mean having a (brave) helper hold it in place or finding a way to securely clamp the tool in place if it won't stay there by itself.
Using a little penetrating oil like PB Blaster wouldn't hurt either.
Rubber? Really? I've had luck loosening corroded fasteners on cars using the (steel) hammer and wrench approach. I don't see how a rubber mallet would transfer enough impact energy to do any good.
Have removed several of the old type BBs using this method and it DOES work for me.
If it were really stuck badly I guess I might get a bigger hammer but haven't needed the 16# Sledge on a bike yet.
I didn't have neither a hammer nor a mallet so I used rubber part of a big adjustable wrench to hammer on the Park BB tool. It came open after a couple of whacks.
