The basics about wheels/tires threads.... (ask and answer questions here!)
Quoted: 7287 Post(s)
Liked 2,365 Times
If you're using tire levers to put tires ON, stop. Don't ever do that. They are only for removing tires.
Bikes: 2009 Fuji Newest 1.0, 2011 Trek 3900 Disc MTB
Yeah I learned that today. I had only ever watched a tire taken off, never had time to watch someone put one on LOL. I learned the right way to do it today. Sometimes I can be a slow learner.
But some people need to remember that replacing my 7 speed hub and wheel, also means replacing the associated contols and that's even more money. Until the contols fail, I'm keeping them because they work just fine.
Bikes: Trek Domane SLR 7 AXS, Trek CheckPoint SL7, Trek Emonda ALR, Trek FX 5 Sport
Quoted: 751 Post(s)
Liked 1,666 Times
meh, I think if it work for you, then no need to change the entire setup, just tweak it where you need to.
Bikes: Old Bike: 1975 Raleigh Delta, New Bike: 2004 Norco Bushpilot
Liked 5 Times
If you send me the money, I will be sure to do that.
Mind you, if a hub is in good condition, but the rim or spokes is a problem, it is possible to rebuild a wheel with new spokes and a new rim using the existing hub. Best solution there is to rebuild the hub, with new bearings. While it is apart you can make sure all the parts, like the axle are good. Later on, if you decide that you want a different hub, you rebuild the wheel using the existing rim on a new hub with new spokes.
Check with your local board of ed. and see if any bicycle mechanics courses are offered, that include wheel building. If you can learn to build your own wheel, then that's going to give you a darn good, long lasting wheel. Wheel building is beyond me, but I noticed my rear wheel is a little out of true, so I either need to take it in, or learn how to deal with it myself. I have some vacation coming up, in about 3 weeks, so I'll pull it off, remove the tire and tube and get out the spoke wrench, see how well I can do.
Yea, re-lacing would be your cheapest route. Spokes are about $1 per, and probably $20 to $30 to rebuild the wheel.
If you want new rims and were to get Deep V rims, they are about $55 per and then rebuild using your existing hub and new spokes. Post to the regional forums for some solid wheel builders in the Columbus area, I'm sure someone can point you to one.
I'll get you the official Wolverine safe-conduct badge.
Road Fan
It's another excellent reason to get your wheels tensioned and trued, at the very minimum. A good builder will advise you about whether your rims are inherently true enough to be tensioned well. Peter White talks about this issue, saying that the priority is to have even and adequately high tension, rather than trueness to the last .005 or whatever inches.
This thread as a Q&A is a great idea, but it highlights that the answers to simple-sounding questions are not usually simple.
If you do lose the ability to shift well, don't be too quick to upgrade the shifters. It may just be the fact that the hub is wobbling around loose on a bent axle.
Mad bike riding scientist
Quoted: 6147 Post(s)
Liked 4,093 Times
[COLOR=Blue]Actually, your tires are 700c x 35. Your wheels have a different designation based on how wide the rims are. Yours are probably 20mm to 24mm wide, meaning you probably have a reference of 622x20 or something like that. Basically 622 = 700c and the 20 is the rim width. If you don't see a marking, measure the rim inside the rim walls. The width of the rims will give you a basic idea of the limits on tire size you can use. I narrower tire would be easier to use on a 622 x 19 than say a 622 x 24, and wider tires of 38mm would be harder to fit on a 17mm width. Even though you might be able to mount them, safety would be a concern.
See this from Sheldon's site.
Mountain bikes regularly run tires that fall way outside of the numbers provided by Sheldon. For example, a Mavic XC717 rim is 17mm wide and you can easily run a 2.3" tire on one. That's a 58mm width. However those are high volume and low pressure tires. Most tires that wide are only rated to 60psi. But then most 32mm+ tires are rated to relatively low pressures too.
Stuart Black
Stuart Black
I grew up just north of Toledo, in southern Michigan, and am a split UM/MSU fan. Trust me, I do at least as well up there as I do here.
That's great news, TKGN! Will look forward to seeing you up here - Steve really is a fine wheelbuilder.
As a Northwestern grad, I live a secret life anywhere other than Illinois and southern WI.
Why don't you find out what it would take to use your old shifters on a 7 speed cassette, which will fit a strong 8/9/10 modern wheel? You may be able to use it as or you may need to take the cassette apart and assemble it with new spacers.
How would I find that out? I would very much like to get a better rear wheel, I heard some rather bad sounding noises at the end of my ride last night. When I would lean to turn I heard noises like the wheel was rubbing the pads, and I had JUST looked at the pads and spacing befor the ride. No curbs, no big bumps, nothing. I just think this wheel isn't strong enough.
I don't know. I upgraded an old bike with a friction system which didn't have that problem. You gotta ask some of these guys, & maybe measure the space between your fw sprocket centerlines-a piece of info which might help them answer without having a 7sp fw handy.
Bikes: Firefly custom Road, Ira Ryan custom road bike, Ira Ryan custom fixed gear
Quoted: 9 Post(s)
BTW, you don't need to use rim tape. You can use veloplugs from velocity. I have them on my deep-Vs. Very cool, light, and no issues with over 5000 miles
Quoted: 751 Post(s)
Liked 1,666 Times
Velo plugs only work on 8mm spoke holes. I use them on my mavic's that happen to have 8mm holes.
I took the wheel in for retensioning and trueing last night. We'll see where that gets us. The front might have needed it too, but I'll do that when I get back if need be.
Got the wheel back today. Shop owner said if it doesn't hold after this, he'll build be a doublewalled wheel with the same hub for around $80. I will likely be taking him up on this if I can afford it after my next race and before the move.
Liked 2,365 Times
That's a very fair price.
Yeah, if this doesnt work out i will definitely do it. I might do it anyways but money is the key point.
