Paint for dummies
Paint for dummies
Can anyone here recommend a good paint for rust prevention on old steel frames? Preferably something that can be applied with a brush, can, or simple sprayer - powder coating is nifty, but a $30 bike frame is not worth $300 in equipment rental fees.
THE Materials Oracle
Bikes: Univega Alpina 5.1 that became a 5.9, that became a road bike... DMR TrailStar custom build
ICI's Hammerite range is available in aerosol cans and tins, and is almost foolproof. Get as much of the rust off as possible, wipe down with white spirits/mineral spirits and spray away.
Bikes: homebuilt FWD recumbents, Genesis 20" folding bike, 1986 Schwinn Tempo, Cannondale Beast of the East, 70's Peugeot
rustoleum thinned with mineral spirits
Google "foam brush rustoleum" paint job. Here is a pic of my last recumbent frame painted by foam brush with rustoleum paint thinned with 25% mineral spirits. I wet sanded between coats. Cost about $7 total.
Bikes: Too many to count
Don't you get brush marks all over the frame if you do it that way. Why not just use a spary paint? It would make your sanding between coats much easier.
Not if the paint is sufficiently viscous... :-)
The wetsanding I did was probably not entirely necessary, but the resulting finish is very smooth. Five or six coats with light, progressively finer wetsanding produces a very nice finish.
Oh yeah, touch-ups either during painting or later are very easy, and because you are not worrying about a spraycan fan pattern, you can leave parts on the frame.
Finally, this is super cheap. A $7 can or rustoleum and $3 can of mineral spirits is literally enough to do 100 frames....seriously.
Living 'n Dying in ¾-Time
One question: When you write "Rustoleum" paint, do you mean their Rustoleum brand, or one of the many other product brands which the Rustoleum Corp. manufactures?
Thanks in advance, and thanks again for the tip w/accompanying image!
Randomhead
Liked 3,698 Times
I was spray painting my milling machine with rustoleum, but I got tired of the overspray. I used a bristled brush with thinned rustoleum, and it could have come out looking really good if I had fixed all the filler that was on the machine. I believe people when they mention this technique, you can't tell there was a brush involved on my mill. It self levels and has a fairly good sheen.
A lot of machine restorers are using this product. There seems to be a bias towards a high quality, big buck art brush, but other than that they seem to be doing the same thing.
Quoted: 101 Post(s)
Liked 49 Times
I've considered the roller rustoleum gimmick, but hadn't seen it done on a bike frame. That looks very, very good. Hmmmm, let's see if they've got my color?
Still stupid and seriously neglected..
That sounds decent for a color coat.
Has anyone tried clear overcoat on top of this?
Has anyone tried using an inexpensive (Wagner) HVLP sprayer? They will spray thinned Rustoleum or any other paint of the proper viscosity. I use this for spraying finish on furniture. It works well. Anyone tried it on a frame?
The only problem with this paint is it isn't terribly durable. Which is ok if one can fix it, but not so great to pass on to someone else. I bought some machines with nice paint jobs, and they were marked up in transit from pretty gentle handling. I don't know what color codes the folks who originally painted them used so patching isn't going to work.
Don't know about a wagner sprayer but there are a lot of inexpensive chinese HVLP guns that are designed to work with regular compressors. They work great, cost a few bucks and could almost be tossed they are so cheap when they come on sale. But it would be a shame.
Quoted: 101 Post(s)
Liked 49 Times
One option for cheap spraying is the Preval aerosol gun, sort of spray can with a jar. They go $4-5 each pour in the paint of your choice and go.
Gluteus Enormus
Bikes: Yes
If you have a compressor then a touch-up gun from Harbor Freight would do the trick. They are cheap and do a good enough job. A half-pint of Rustoleum which you can get from any big box home center will go a long way when thinned.
