Light & Good for Tricking?
I'm looking to build my own fixed. Any suggestions on frames or components that are strong/good quality, light, but still good for tricking? Suggestions could be brands, things to looks for, experiences, blah blah blah.
I've got a budget, most likely anywhere from $400-$650.
Thanks, anything helps
--Dia
--Dia
Live without dead time
The best thing you'll find for doing tricks on a fixed gear bike is to go with a Volume Cutter frame, and some strong ass wheels. Everything else is just finding the parts that fit for what you want to do.
there's also the Bruiser by Milwaukee bikes which was designed with tricks in mind. You should be able to build something at the upper end of your budget based on either of these frames
https://www.tricktrack.org/forums/viewtopic.php?t=973
Thanks
I'm not super hardcore, and doubt i will be bmx-ing on my fixie, so i don't want something super fragile like a bianchi, but i'm also not ready to drop $1000 on a bike.
What do you think about this Felt?
https://www.feltracing.com/09-catalog...-brougham.aspx
Also, do you know if EAI has made another version of the brass knuckle? Or if something like that is even a good choice?
They have a godzilla or some such ****. I'm not seeing an EAI branded Aluminum track Frame.
https://www.euroasiaimports.com/produ...dCategory=1274
pcbc
Bikes: motobecane mirage, schwinn varsity, a tallbike
I spent over $400 on a conversion, but quite a bit of that was tools, and not completely necessary. Hell, I'm only using 3 parts from that bike anymore.
If you're new to biking, I'd say pick something up CHEAP first and learn what you like as inexpensively as possible.
My first bike was a HORRIBLE decision.
I've already done the whole conversion thing, and it was much more trouble than it was worth; i got tired of putting money into it.
I'm only a teenager, that's why i'm not going to drop a ton on a bike.
I just would like to find the best i can get for the money, and something that will last.
What did you guys think about that Felt?
Gay Israel
Bikes: '83 Bianchi Nuovo Racing, '89 Bianchi Sport SX
I find small children (under 5 works best) to be exceptionally light and very easy to trick.
Bikes: Pake,Shogun,Nishiki,Motobecane
Well,light and tricking don't really work together all that well.You'll have to compromise somewhere.For tricking you'll want something solid,but solid means heavier.Low end Steel frames might be something to look into(high end steel tends to have thinner wall tubing which makes it light but not so good for abuse).Another option is alu.Lighter than steel,but the same deal(compare 6061 tubing to 7005).Also the fork is a issue with alu frames.Carbon rides nice but is not the best for harsh tricks,aluminum forks are solid but give a harsh ride and steel forks kinda look out of place as most aluminum frames tend to be oversized tubes.
helmet brake
Bikes: Kilo TT
bikebeerbeard
Bikes: 09 Felt Brougham
I ride a brougham. If you want to do barspins you'll need to switch out the fork, there's no clearance.
Not that that's what i do with my bike as I run a brake...
Just sayin
Just sayin
senior tarckass
Bikes: 2001 bianchi pista/ affinity low pro
Bikes: felt f85
Bikes: EAI Bareknuckle, 1981 Gios Aerodynamic, Giant Boulder
