Worn Rims
Worn Rims
Hi,
My rims have started wear and change color. It looks like deep grooves but they aren't. Is there a surface coating or something that has worn off? They are Mavic T138.
Thanks.
Thanks.
Bikes: Bianchi, Miyata, Dahon, Rossin
Liked 5 Times
normal. rims wear out eventually
Food for thought: if you aren't dead by 2050, you and your entire family will be within a few years from starvation. Now that is a cruel gift to leave for your offspring. ;)
https://sanfrancisco.ibtimes.com/arti...ger-photos.htm
It shouldn't be too surprising that rubbing black rubber on metal will make the metal just a little darker as the light reflection surfaces change and the rubber gets entrained into tiny voids in the substrate.
Liked 7 Times
The brake pads are probably too hard. Replace with soft pads, I'd try KoolStop salmon (or black) brake pads.
Al
Al
