Frame Pump
Frame Pump
Old 02-08-02 | 08:34 AM
bjlaw's Avatar
20 Anniversary
Frame Pump
Does anyone know of any frame pump that will fit on a Trek 5200? I have two cages for water bottles so I need it to fit on the top tube but the rounded joint at the seat tube makes it tought to fit any pump I have found so far.:confused:
BJ
When victory in battle is assured, time to tighten helmet strap.
bjlaw is offline
Reply
Old 02-08-02 | 11:03 AM
25 Anniversary
Bikes: Lots
Why not get a mini-pump with a clip (usually included) that mounts underneath the water bottle cage? Blackburn, Topeak, Specialized,....etc. all make some.
"Life is not a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside, thoroughly used up, totally worn out, and loudly proclaiming, "WOW, What a Ride!" - unknown
"Your Bike Sucks" - Sky Yaeger
a2psyklnut is offline
Reply
Old 02-08-02 | 11:19 AM
bjlaw's Avatar
20 Anniversary
I had a mini pump and it was fairly worthless. I would prefer a full size frame pump if that is possible.
BJ
bjlaw is offline
Reply
Old 02-08-02 | 11:41 AM
lotek's Avatar
Titanium Club Membership
20 Anniversary
Bikes: 1 trek, serotta, rih, de Reus, Pogliaghi and finally a Zieleman! and got a DeRosa
would a umbrella pump clip work as an alternative?
I seem to recall alot of bikes using them when there
was no pump peg brazed to the frame.
The old Campy ones (go retro) seem
readily available.
Marty
Sono più lento di quel che sembra.
Odio la gente, tutti.
Want to upgrade your membership? Click Here.
lotek is offline
Reply
Old 02-08-02 | 12:50 PM
RainmanP's Avatar
Mr. Cellophane
20 Anniversary
BJ,
I don't know if you will find a pump that fits those rounded corners. I understand your disdain for minipumps. I had one rated for 90 lbs that wouldn't get above 60-65. However the Topeak Road Morph, more of a mid-size, will EASILY get my 25 mm tires to 120 (max for the tires) and is rated for 160. It has a fold down foot peg, fold over T-handle, hose with quick release, and built in guage which features combine to make it almost as easy to pump as a floor pump. As far as I am concerned it has to be the best carry along pump I can imagine. It comes with a velcro on clamp that clamps on the top tube. I will make you the same bet I have made others. Try one, and if it doesn't meet your needs I will buy it from you for whatever you paid for it. I've been thinking about getting one for one of my other bikes anyway. Has to be a Road Morph though, not the mountain bike version.
Regards,
Raymond
If it ain't broke, mess with it anyway!
RainmanP is offline
Reply
Old 02-08-02 | 01:11 PM
bjlaw's Avatar
20 Anniversary
Thanks Raymond,
I will look into the Topeak Road Morph. Sounds like you have had really good luck with it.
BJ
BJ
bjlaw is offline
Reply
Old 02-08-02 | 04:38 PM
20 Anniversary
Have you thought about the compressed air cartridges? You buy a gizmo that the canisters fit into to inflate either presta or schrader valves. I carry along a plastic air gauge to make sure I have the right pressure. This is, I am assuming, just to carry along for road emergencies and you have a regular floor pump at home. The cartridges at a bike shop can be expensive, so buy them at a hobby shop for a lot less $.
sunnybear is offline
Reply
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
