Carbon Road Wheels - ??
Hi,
I am looking to buy a good set of Carbon Deep section road wheels. I want to use them for road races and time trials and they need to be light enough for climbing.
I have been looking at Zipp 404 or Easton EC90 Aero wheelsets. I would prefer clincher wheels, but would also consider tubulars.
Which wheels would you recommend?
Thanks, BK.
Thanks, BK.
Bikes: Specialized Tarmac SL2, Specialized Tarmac SL, Giant TCR Composite, Specialized StumpJumper Expert HT
Seriously, are you people blind?
Bikes: Bianchi, Miyata, Dahon, Rossin
Liked 5 Times
Get both.
Food for thought: if you aren't dead by 2050, you and your entire family will be within a few years from starvation. Now that is a cruel gift to leave for your offspring. ;)
https://sanfrancisco.ibtimes.com/arti...ger-photos.htm
Peloton Shelter Dog
Liked 5 Times
here you go, read this: https://www.bikeforums.net/road-cycling/470422-introduction-road-cycling-forum.html
So did you not see the racing forum or did you just not care? I don't have any experience with either of the wheels you mentioned but I do know that you will get better answers in the racing forum. I just don't understand why so many people don't "see" it when they post.
Lanky G-Raf
Bikes: Giant TCR0 aluminum/carbon with ultegra components. Sintesi (Italian) lugged steel road bike, circa 1987.
It was a question about gear to use while racing...
Tubular wheels will be a little less expensive than clinchers. If you ever flat during a race you're pretty much done anyway. Many people will claim lower rolling resistance on tubulars. I'll attest to a smoother ride. And you can run them anywhere from 60-160psi, depending on the race you're doing.
Quarq shill
Bikes: 08 Felt F4, 05 Fuji Team SL, 08 Planet X Stealth, 10 Kona Jake the Snake, 03 Giant OCR flat bar.
1. How are tubulars less than equivalent clincher?
2. The tubular/clincher crr debate is still up in the air. The extra steps you need to go through to get the rr the same is probably going to turn 95% of racers away from tubulars.(recent tests from Al Morrison(AFM) on biketechreview.com says something like 3 tubes of glue PER WHEEL with a tubular to match a top clincher with latex tube)
3. Running them at 160 will do nothing but shake your fillings out.
I did the tubular thing for a couple of years, and still do for cross, but in this day the average racer will be just fine on a top quality clincher.
Ho-Jahm
Quoted: 5 Post(s)
There's also the ~200 gram difference between carbon tubulars and carbon clincher wheelset, plus the weight difference of the tires/tubes. ~180-200 grams for a clincher + ~60 grams for a latex tube vs. ~220 grams for a tubular with tube and glue.
I figure weight difference for tubular vs. clincher wheelsets and tires is ~250-300 grams but I could be mistaken on the tire weights.
Just for the record, rotating weight doesn't mean anything.
Resident Alien
Quoted: 349 Post(s)
Liked 10 Times
I've been racing the Token C-50's (clinchers) for two seasons now. Absolutely top notch wheel and VERY tough. I've had fantastic luck with Reynolds tubulars, and found Zipp tubulars to be as durable as saltine crackers. Easton was using rebranded saltine rims but have switched sources on their new product. The Zipp clinchers have less of an issue with durability, but are priced well above a lot of other offerings.
Two teammates have the Reynolds clinchers and love them.
Quoted: 15 Post(s)
Liked 27 Times
the ping i heard during tonight's race was a broken spoke (on the rear wheel drive side).
i'm far from heavy. maybe my cottage of wattage was in overdrive?
guess they were tough enough that i didn't notice until after the race.
Elite Fred
Bikes: 2009 Spooky (cracked frame), 2006 Curtlo, 2002 Lemond (current race bike) Zurich, 1987 Serotta Colorado, 1986 Cannondale for commuting, a 1984 Cannondale on loan to my son
Quoted: 60 Post(s)
Liked 42 Times
Paging Psimet...
Psimet, are you out there?
To the OP: Find a post by Psimet and click on his signature. That is the deal on aero carbon wheels.
I eat carbide.
Bikes: Lots. Van Dessel and Squid Dealer
Quoted: 1325 Post(s)
Liked 1,306 Times
Thanks for the mention. I do have 50mm carbon clinchers and tubulars right now. Same rim as Token,neuvation,Williams,planetx,Blackwell,etc.
Mine are 24f/28r drilling though and this is what makes the difference. You can select whatever hubs and spokes and lacing you want as well.
Prices are unbeatable. End commercial.
PSIMET Wheels, PSIMET Racing, PSIMET Neutral Race Support, and 11 Jackson Coffee
Podcast - YouTube Channel
Video about PSIMET Wheels
Bikes: '07 Excalibur, '08 Anthem 1, and some others
