ARGHH - I hate BB installation
Muscle bike design spec
Bikes: 70 Atala Record Proffesional, 00 Lemond, 08 Kestrel Evoke, 96 Colnago Master Olympic, 01 Colnago Ovalmaster, 76 Raleigh Gran Sport, 03 Fuji World, 86 Paramount, 90 Miyata CF, 09 Ritchey Breakaway CX, Bianchi Trofeo, 12 OutRiderUSA HyperLite
Even with new frames I often have to get the BB shell re-tapped for a cartridge to install. Today I finally got around to installing the new ISIS BB into my Nashbar touring frame (nice green, lots of braze-ons).
One side went in without issues. The other tightened down by hand a few turns then seized after a couple turns with the appropiate too. I was unable to back it out. I had to go to Sears and buy a 36mm socket. It then took 30 minutes with the 1/2" socket wrench, standing on the BB shell and whacking it with a rubber mallet to remove the BB. It's removable shell is trashed, the BB shell threads are trashed! I hate life.
On the positive side, the external bearings installed flawlessly on my Ritchey Breakaway frame. I just picked up a chain and 11-32 9 speed cassette. Ritchey OCR road wheels should arrive Tuesday and I'm having a set of Ritchey WCS hubs built with CX width Salsa rims by Jermemy in AZ.
Korval is Ships
See my Hyperlite 411 it's the photo model on OutRiderUSA web page
gone ride'n
Bikes: Simoncini, Gary Fisher, Specialized Tarmac
Sometimes it's just cheaper to let the LBS take care of the nasty jobs like headsets and BBs
That said, I doubt if I'll every buy a fancy BB thread chaser. I've also never successfully removed an old style fixed cup side of a BB.
Korval is Ships
Liked 6 Times
Sometimes you can pick up a used bb thread chaser I got my Hozan C-402 (set of 2 - one for each side) for less than $60. I learned the hard way (an incident not dissimilar to yours) that it's worth running the thread chaser through the bottom bracket before installing a new bb every time. It doesn't take much to screw up the threads.
I know we don't like to see bike shops going out of business, but if one in your area ever does announce it's closing the doors... well, you might be able to pick up some real useful tools at next to nothing.
A conclusion is the place where you got tired of thinking. - S. Wright
Favorite rides in the stable: Indy Fab CJ Ti - Colnago MXL - S-Works Roubaix - Habanero Team Issue - Jamis Eclipse carbon/831
Just a little bit of dirt, grit or paint in the BB shell will ruin your whole day, Ask me how I learned that lesson.
My rule is that the parts have to go together with just finger pressure, and with out the spindle first, If anything more than finger pressure is needed, something is amiss and should be looked into before wrenches are used. It usually just needs more cleaning, I use a spray can of brake cleaner. And put some grease on the threads.
feros ferio
Quoted: 1391 Post(s)
Liked 1,322 Times
Try installing a cartridge BB in a freshly repainted ca. 1960 frame. At least I don't have to worry about it coming loose.
Wow, I've installed a zillion bottom brackets. New frames, old frames, I've never had a problem, neve rhad to chase threads or face the shell. Now that I've written it, I guess the Bottom Bracket Fairy will have my name on file!
I dropped the frame and BB off with a guy who used to run the Pedal Shop in Ashburn, VA. He's got another GPX BB and the tool to chase the threads.
Meanwhile my Ritchey road wheelset came in for the CX bike. I also scored a TREK 2100 composite bike with new wheelset and commuting gear for an obscenely low price. I'm working on a cash/trade deal with a coworker. He commutes on a TREK hybrid and is tired of being dropped by the roadies. I hope to profit a slightly used HID system.
Korval is Ships
Bikes: Bridgestone RB-1. Nicely restored
Quoted: 13 Post(s)
Liked 9 Times
There are certain bicycle jobs I just won't do. These include, but are not limited to:
-Bottom bracket installation.
-wheel truing.
-headset installation. (Nooooo!!!)
The aggravation of these is just not worth it. I need professional hands and eyes on these jobs.
Man, I love living in close proximity to Harris Cyclery.
-wheel truing.
just keep riding
Quoted: 173 Post(s)
Liked 33 Times
I have installed many bottom brackets and have rarely had any problem. I keep an old BB with steel cups around to use as a cheap, light duty thread chaser. I install the old BB and its harder steel threads will usually cut through any minor defects in the frame threading with firm but not extreme arm power to the wrench. Then I remove the chaser BB and install the real one. I have only come across one frame that could not be prepped in this way. I took it to my LBS and they were able to clean up the threads with the proper tools. I then installed the BB myself.
Boomer
Bikes: Diamondback Clarity II frame homebuilt.
Quoted: 16098 Post(s)
Liked 1,457 Times
Even the factory messes this up sometimes. My first (this time around) bike about 10 years ago rode just fine. When I had learned enougt to want to alter and rebuild it, the BB wouldn't come out. 1 bike shop, 3 tech's and some big wrenches later and it still wouldn't come out. Diamondback was good enough to give me a new frame for my trouble and my shadow career as a bike mechanic began.
My early attempt with a 2x4 and a rubber mallet was unfruitful and embarrassing. No permanent damage was done. The recent Nashbar headset tool worked like a charm. I also got the headset cup remover and the star nut installer - they worked great. I've also used a clamp on guide for cutting forks [acquired by trade] and seat tubes successfully.
Korval is Ships
Boomer
Liked 1,457 Times
That's a great idea. I actually have a new set of steel BB cups that I bought last year [for some unknown reason]. I'll give that a try next time.
Have installed at least a dozen BB's over the years. Had a Ridley frame that in the end it was just more productive to have the LBS chase the threads and face the BB area.
On cutting a steerer tube. I found some clamps that are used to hang copper plumbing pipe. Faced one side to make sure it was flat. Just put the clamp on the tube after I have measured it a dozen times to be sure and works great. I know this is hard to visulaize.
Bikes: Schwinn MTB, Surly LHT, Cannondal CADD8ek XO
Bikes: Litespeed Classic, Lynskey
I've installed a number of BB's in steel, Ti and Aluminum frames ... I guess that I've been lucky because there's been nary a problem. I also made up my own tool for headset installation -- threaded rod, washers etc. -- that too went well. My son-in-law has the proper headset installation tools, including the Chris King adapters -- I used his last time -- but this time he and his tools were 1250 miles away -- I was anxious to ride the new frame and too cheap to buy the tools, so I bought the DIY parts at Ace Hardware.
I've also built and trued wheels ... so I guess that I'm a true bike nerd !
