What is the most effective way to clean oily brake pads?
Hi,
Anyone know what is the best way to clean the oil from disc brake rotor and pads?
I tried hot water, burning it out going down hill, and alcohol and the only method that came close was braking full force going down a big hill, but this only worked for some time. I think when the brake cools it becomes less effective again.
Suggest product called 'Brakleen', automotive department or auto parts store. Stuff is vile until it evaporates, use outdoors. Spray brake cleaner.
I have some "bike cleaner" that's essentially automotive brake cleaner minus a few of the less bike-friendly solvents.
Alternately, remove pads and give a spritz with vastly cheaper automotive brake cleaner.
Bikes: A beautiful columbus steel frame, 1986 Schwinn Voyageur touring bike, Currently Undergoing Overhaul
Brake Cleaner, Cheap and you can get it at any auto parts store. Make sure there are no people, buildings, wildlife, pets, grass, and a whole list of things nearby. Use it outdoors. That s**t will eat through anything. However, like Operator says, I've used rubbing alcohol on car disk brakes and it works, just not as well as brake cleaner.
Yeah, alcohol is a polar solvent and won't dissolve oil & grease. Brake Cleaner typically has a combination of non-polar aromatic compounds that do a very good job on removing oil & grease from brake parts.
Great State of Varmint
Liked 15 Times
If someone would read and type the contents of a can - or three if three of you do - of their favorite brake-cleaner, I, as an organic chemist (which DannoXYZ also seems to have a good knowledge of) could suggest what to buy at a hardware-store for much less than the stuff that's sold specifically for brakes in the automotive section.
My current guess is Xylene - aka Xylol. But that's a guess - before you run off to TruValue.
I have senior moments...
Bikes: Many
Mostly your pads are done when contaminated. You might be able to bake off the contaminant with high heat, but depends on pad compound and your method. Best is to not contaminate your disc brakes in the first place, ever. Rotors can be cleaned/sanded. Replace the pads.
mechanically sound
Once you factor in the: a.) time it takes to "clean" the pads and the b.) questionable results of the whole process; getting new pads right away(before trying to clean the old pads) is the cheapest route IME.
Dish detergent is a great grease and oil cutter and won't react with the brake pad material. But I'm with the replacement guys. Just make sure the braking surfaces on your wheels are squeeky clean.
Elitist Troglodyte
Bikes: 03 Raleigh Professional (steel)
Albany Brake Parts Cleaner - "Contains Toluene and other petroleum distillates."
Advanced Auto Parts BPC mentions Tetrachloroethylene, Carbon Dioxide (!), and the possibility of death or worse.
Stupidity got us into this mess - why can't it get us out?
- Will Rogers
- Will Rogers
Here's some active ingredients of common brake-cleaners found at auto-parts stores:
Champion 4126P Brake Parts Cleaner
90-94% PERCHOLETHYLENE cas=127-18-4
3-7% XYLENE cas=1330-20-7
Pyroil Brake Parts Cleaner
90-100% TETRACHLOROETHENE
Brakleen Brake Parts Cleaner
45-55% ACETONE
22-32% TOLUENE
15-25% METHANOL
3M 08880 High Power Brake Cleaner
10-30% 3-METHYLHEXANE
10-30% HEPTANE
10-30% PROPANE
10-30% XYLENE
7-13% METHYL ALCOHOL
5-10% 2-METHYLHEXANE
3-7% ETHYLBENZENE
1-5% 2,3-DIMETHYLPENTANE
1-5% 3-ETHYLPENTANE.
1-5% DIMETHYLCYCLOPENTANE
1-5% METHYLCYCLOHEXANE
<0.3% TOLUENE
45-55% ACETONE
22-32% TOLUENE
15-25% METHANOL
10-30% HEPTANE
10-30% PROPANE
10-30% XYLENE
3-7% ETHYLBENZENE
<0.3% TOLUENE
The traditional way for automobile brake shoes (this pre-dates disc brakes) was to soak them in gasoline, place them somewhere safe (like on a concrete driveway), and light them on fire. I have no idea if the adhesive used on bike pads would hold up to this abuse.
Map maker
Bikes: Ventana El Ciclon, Walt Works 29er, Specialized Enduro (fixed up for my son).
Advisor
I use a file or sandpaper. I rub the brake pads on a medium or fine file to remove some of the old brake pad materials. Sometimes I use sandpaper on a flat metal surface such as a table saw and rub the brake pads on the sandpaper.
mechanically sound
Won't do much good on disc brake pads- they soak up the oil like a sponge all the way through.
Bikes: Many
omnipotent, where do you work to possibly see enough contaminated bicycle brake pads for "hundreds" of cans of that stuff?
