Suggestions to Fix Overlap on 50cm TT
Old 06-19-09, 06:12 PM
Bikes: "el chadillac"
I've read the other threads discussing toe overlap, but in an emergency situation (having to swerve), the over lap would be trouble. I was hoping to learn what others have changed (in terms of equipment) to mitigate the toe overlap on the 50cm tt. Any clips that are shallower? Different pedals? Any other suggestions.
I have read the threads discussing the rider aspect of the problem, but those comments are still appreciated.
chadr is offline
Old 06-19-09, 06:23 PM
scraper bikes
Bikes: eddy mercxier kilo tt
welcome to the world of track bikes...not designed with quick swerving in mind.
possible solutions
-get a different bike
-get a new fork with a different rake
-get a 650c wheel
-become very familiar with bike...how much you can and cannot turn during emergency situations
-get clipless pedals/shoes (might help a little bit)
-if your bike is too small, move up to the 53 or the 55cm kilo (less toe overlap)
comptechgsr is offline
Old 06-19-09, 07:02 PM
Yan's Avatar
Quoted: 1916 Post(s)
Liked 633 Times in 433 Posts
The ball of your foot needs to be over the pedal axle. Changing clips is not a solution.
Yan is offline
Old 06-19-09, 07:04 PM
Comanche Racing
PedallingATX's Avatar
Bikes: Presto NJS build, Specialized Allez Pro w/ full Dura Ace and Ksyrium SLs, 1990something Specialized Sirrus
get a bike w/ more roadish geometry. Kilo is pretty steep. Getting a less track fork could be a good idea. Also a good opportunity to throw some carbon fiber on there!
PedallingATX is offline
maddyfish's Avatar
Bikes: KHS steel SS
Use a freewheel and stop pedaling during emergency moves.
maddyfish is offline
Old 06-19-09, 08:52 PM
adriano's Avatar
Bikes: https://velospace.org/node/18951
its not all that steep at all.
α
adriano is offline
Old 06-19-09, 09:21 PM
on Baby Charlie Concept~
muckymucky's Avatar
yea get a 26" size wheel with a very small tire (do they make 23cm tires on 650c wheels? not sure.), try your local bike shop for a used front wheel!
muckymucky is offline
Old 06-19-09, 09:32 PM
helmet brake
jakerock's Avatar
Bikes: Kilo TT
I thought that this was gonna be a problem too... but in practice it really hasnt been.
I have a 57cm and size 12 feet... My toes hit the tire every once in awhile but I have never gone down because of it... Might be different on a smaller frame though I understand.
jakerock is offline
Old 06-19-09, 10:31 PM
Comanche Racing
what I mean is that the wheelbase looks pretty short (to me). I don't know that much about bike geometry, but it definitely looks like a much shorter wheelbase than some other production FG bikes i've seen.
Old 06-19-09, 10:49 PM
scraper bikes
going clipless from cages has helped many in the fight against toe overlap.
FACT
Old 06-19-09, 10:57 PM
passerby's Avatar
Bikes: 08 Schwinn Madison
possible solutions
Bad advice... everything else you said was on the money though
passerby is offline
Old 06-20-09, 02:30 AM
scraper bikes
If your bike is too small (or doesn't fit for that matter), get a bigger size (one that fits you properly)...i'm pretty sure that goes for many other a thing as well. In addition to having a better overall fit, the larger the kilo, the less toe overlap it will have.
Old 06-20-09, 06:11 AM
Thank you all, this has been very useful. I'll just pray before I go out each time.
chadr is offline
Old 06-20-09, 09:09 AM
Bikes: 50cm Black Kilo TT
if you like clips and straps get feetbelts or something similar. I ride a 50cm kilo and they work great. You can slip your foot back a little bit when you're turning tight ones and the pedal clears the wheel.
Nietzsche is offline
Old 06-20-09, 09:10 AM
¡Senor Member!
time bandit's Avatar
if im going slow enough that toe overlap is an issue, in an emergency situation, id just stop. :-\
time bandit is offline
Old 06-20-09, 11:04 AM
curmudgeon
psirue's Avatar
toe overlap is a common pitfall of track bikes. so if toe overlap is a problem that you cannot deal with, dont ride a track bike.
psirue is offline
Old 06-20-09, 03:00 PM
skeletor3000's Avatar
Bikes: Cannondale R600 CAAD5, 1973 Takara, 2009 Mercier Kilo TT
I really don't get how this is such a huge deal. It seems like if you're going slow enough to turn your wheel that far, you're going slow enough that scuffing your foot on the wheel won't matter.
skeletor3000 is offline
Old 06-20-09, 03:02 PM
I ride a 47cm and don't notice any overlap unless I am doing some really tight circles.
tgscordv6 is offline
Old 06-20-09, 03:27 PM
adriano's Avatar
im fine on my 47 as well. be a man.
α
adriano is offline
Bikes: Fuji Track, Half built 70s Azuki
the only times i've had had a problem with toe overlap while riding involved getting started from trackstands at stoplights if I had the wheel turned too much. It isn't really a problem unless you're average speed is like 4 mph.
dayvan cowboy is offline
Old 06-20-09, 05:04 PM
GO, Mordecai!
Syncmaster's Avatar
Same for me except I ride the 50cm like the OP, and I have had the same experience as Jakerock. You get used to it, and even at slow speeds, your feet learn where they should be before you make a tight turn in either direction.
Syncmaster is offline
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
