Go Back  Bike Forums > Bike Forums > Advocacy & Safety
Stronger Material?
Advocacy & Safety Cyclists should expect and demand safe accommodation on every public road, just as do all other users. Discuss your bicycle advocacy and safety concerns here.
Stronger Material?
Old 06-25-04 | 03:24 AM
Flantlander^
20 Anniversary
Stronger Material?
I am working on building my bike from my own parts. I have a choice of Chromoly or Titanium. I do wheelies and race ( Rarely ramps but sometimes ). Does anyone know what material I should use?
(Its the "Hub Axle")
BiKe_GuY666 is offline
Reply
Old 06-27-04 | 12:56 PM
jeff williams's Avatar
I couldn't car less.
20 Anniversary
Bikes: Ritchey P-series prototype, Diamondback, Nishiki Triathelon Pro.
Titanium ( added to Alu composites ) increases hardness, and is stronger and lighter than chromoly steel.
No idea of its tensile properties- another kind of strengh Alu does not have.
But I might be wrong...
jeff williams is offline
Reply
Old 06-28-04 | 12:09 PM
20 Anniversary
Hub axles have a fixed dimension. Steel will be stronger, stiffer, but heavier. For hard use go with steel.
Ti axles are strictly for lightweight use.
This is not the case with Ti frames, where you can pick dimensions to favour the material.
MichaelW is offline
Reply
Old 06-28-04 | 12:12 PM
20 Anniversary
About Ti pedal axles? opinion? Good post.
Reply
Old 06-28-04 | 06:17 PM
khuon's Avatar
DEADBEEF
20 Anniversary
From: Catching his breath alongside a road near Seattle, WA USA
Bikes: 1999 K2 OzM, 2001 Aegis Aro Svelte
I have Ti pedal spindles on both my MTB and RB. I believe the stated weight limit on them was something like 180lbs. I've never cracked a Ti axle though but I'm only around 140lbs.
1999 K2 OzM 2001 Aegis Aro Svelte
"Be liberal in what you accept, and conservative in what you send." -- Jon Postel, RFC1122
khuon is offline
Reply
Old 06-29-04 | 05:58 AM
sch
20 Anniversary
Do not use Ti for axles, it is marginal enough as a BB axle, in a wheel it is asking
for trouble. Your application needs a lot of strength and an oversized solid axle
would be a good idea. It should be made of a rated chrome moly with a number
attached, not an innominata steel. Steve
sch is offline
Reply
Old 07-09-04 | 10:34 AM
Seanholio's Avatar
20 Anniversary
Bikes: Vision R40 - recumbent, Gunnar Crosshairs
Here's some info on Ti pedal axels.
https://www.bebop.com/old%20web%20tex...edmata101.html
Seanholio is offline
Reply
Old 07-09-04 | 11:47 AM
slvoid's Avatar
2-Cyl, 1/2 HP @ 90 RPM
20 Anniversary
Bikes: 04' Specialized Hardrock Sport, 03' Giant OCR2 (SOLD!), 04' Litespeed Firenze, 04' Giant OCR Touring, 07' Specialized Langster Comp
The same size rod, steel would be stronger but a lot heavier.
But to bear the same load, there would be more Ti but it would be lighter. Great for aerospace where weight is much more important than size.
slvoid is offline
Reply
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
