Question about tire size.....
We were riding today, and my riding partner asked me why wheels are 700c, and not say 750 mm, or 710, or 690 and so on. Why was 700 chosen as the standard size. I know that they are the same diameter as tubular tires, and so you can easily swap wheels without changing the brakes, and etc... But, why was the size tubulars, or 700c, or for that matter 27 in. made the standard size?
I have a guess, but I'd like to know if someone knows fer sher.
Marko
Marko
Quoted: 101 Post(s)
Liked 49 Times
The 700c is 622mm. Why is it the standard instead of something else .... Same reason all DVDs are the same format.
Still stupid and seriously neglected..
aka Phil Jungels
I'm just glad they finally settled on one.......
Disraeli Gears
If you've ever delved into bike frame design a bit, you've probably realized how finely calibrated everything is, and how changing the size of wheels would throw all kinds of things out of whack in a hurry. My guess is that the Continental constructeurs and English ones arrived pretty much at the two very close wheel/rim sizes because it made frame design efficient and simpler, to accommodate the widest variety of sizes necessary with the fewest modifications to the frame configuration.
Great State of Varmint
Liked 15 Times
Just wait until some genius<koff> with a big and expensive marketing-firm, comes up with "Biopace" wheels. Then it begins... Do you want the 685/719C? Or the 692/707C? Or the.....
I think they sorted out the basics before the turn of the last century. Google "1884 safety bicycle".
If they made the diameter larger, the frames would have to be wider so the spokes didn't get too steep, and smaller frames would cause the front wheel to hit your foot unless the frame were so long that you'd have to reverse your stem, which would make the bike handle funny.
I probabaly can't even conceive of all the reasons, but many, many different combinations were tried and they hit upon "70cm" as the ideal size. I know Velocio felt a 50cm wheel with 5cm tires was the more ideal solution for many situations, though.
Liked 15 Times
"700C" is not, nor has it anything to do with, 70cm - cm inferring centimeters. So none of it truly makes sense. I just had an utterly bewildered guy here to deal with a wheel-problem. I had to explain all this to him. I asked him if he was still confused. He said he was. I told him I was glad he was as only a certifiable lunatic could make sense out of this system. He agreed.
Quoted: 101 Post(s)
Liked 49 Times
Except it isn't 70cm, it's 622mm. 700C is just the name of that particular size. There is also a 650 that isn't nearly as common.
Liked 15 Times
And a 700A, too! Weeeeeeeeee!!
"I'll be happy to see those nice, young men in their clean, white coats as they're coming to take me away!"
Hair Club Member
Bikes: '86 Miyata 310 '78 Raleigh Sports 3-Speed
as I understand it
I seem to recall that "700c," "650a" and "650b" are traditionally the French designations, derived not from the size of the rim, but the outside diameter of the rim plus the appropriate tire. We have always called "650a" "26x1 3/8" in the English-speaking world -- but now that the U.S. isn't really English-speaking anymore it's hard to even find a new bike that is mounted with 26x1 3/8 rims -- the new thing seems to be the 559mm "clunker" size (the so-called "26 inch" relic from the 40's) I thought we buried in the 50's. Apparently the mountain bike brought it back to life (I wouldn't know -- I still don't know why people push those clunkers around). The French "650b" seems to be a non-starter in the rest of the world, despite an effort to import this unneeded size, so close to the "middle-weight" 26x1 3/8 we have always used in the English-speaking world. (Of course, the whole Schwinn "S5" and "S6" middleweight sizes just muddies the water more.) Some see much uniformity and logic in bicycle tire sizes -- but how they do is a mystery to me.
Bottecchia fan
Bikes: 1959 Bottecchia Milano-Sanremo (frame), 1966 Bottecchia Professional (frame), 1971 Bottecchia Professional (frame), 1973 Bottecchia Gran Turismo, 1974 Bottecchia Special, 1977 Bottecchia Special (frame), 1974 Peugeot UO-8
Quoted: 33 Post(s)
Liked 10 Times
And yes, I'm pretty sure the "700" designation indicates a 70cm outside diameter of the origial 700C size wheel/tire combination. It was the standard in the old days to make all of the wheel/tire combinations a standard outside diameter and to vary the rim size depending on the physical dimensions of the tires. IIRC the original 700C size was much wider than the typical tire today and had a larger outside diameter.
1959 Bottecchia Milano-Sanremo(frame), 1966 Bottecchia Professional (frame), 1971 Bottecchia Professional (frame),
1974 Peugeot UO-8, 1988 Panasonic PT-3500, 2002 Bianchi Veloce, 2004 Bianchi Pista
Old English roadsters had/have 28" (635) wheels, with 90mm front axle spacing and 120mm rear hub spacing. They also have long wheelbases and relaxed frame angles (your feet won't hit the front wheel) AND they were made to handle cobble stones, dirt paths, gravel roads, etc. And they last FOREVER.
