Just finished building my bike rack (PICS)
Quoted: 47 Post(s)
Liked 29 Times
For the last several months I've been having a hard time finding a place to keep all my bikes. Right now there are 9 (nothing compared to some of you), and they have been splitting time between the garage and the living room. I wanted to hang them from the ceiling in the garage but didn't like the idea of having hooks in a fixed position, so I made this instead.
It allows the bikes to move front to back and side to side so I can make adjustments for wheelbase. I can sqeeze them in close together when just being stored or spread them out to make it easy to get a particular one down.
I need to make more hooks before I can get the other bikes up there, but so far it's much better than before.
stringbreaker
Bikes: specialized crossroads hybrid 2006 Raleigh Cadent 2 1971 Schwinn Varsity, 1972 Schwinn Continental, 1977 Schwinn Volare (frame)
Quoted: 9 Post(s)
Nice job with readily available materials. I like the rollers so the bikes can be slid together or apart for easier removal
(Life is too short to play crappy guitars) 2006 Raleigh Cadent 3.0, 1977 Schwinn Volare, 2010 Windsor tourist. ( I didn't fall , I attacked the floor)
Bikes: (3) 1970's Raleigh Sports, (1) 1968 Robin Hood 3 speed, 1974 Raleigh Grand Prix, 1976 Raleigh Grand Prix, 1969 Peugeot UO-18, 1971 Peugeot UO-08, 1980 Giant road bike, 1954 Humber, 1940ish Hercules Popular, 1963 Dunelt, 2007 Trek 3700 mountain bike
That is so cool!!
I'm assuming that you used lengths of conduit to hang the bikes from. How did you attach the garage door wheels to the conduit? Did you insert a threaded plug into the conduit that would accept a bolt?
aka: Mike J.
Nice job. Looks like you'v e come up with a home version of the Easy Glider rack system (not sure if I've got the name right). Gives me more ideas for my garage situation.
Please share your build details, thanks.
steel lover
Bikes: Bianchi Alloro, Miyata 710, Fuji Espree Fixie convert
VERY nice. I like the roller idea. At first, was thinking "Big deal, why share".... now I'm thinking, "THANKS, I now have a reason to buy more bikes "
Quoted: 47 Post(s)
Liked 29 Times
I wish I could take credit for the idea, but my inspiration was the VeloGlide, which does the same thing but for a lot more money.
The rails are from a garage door removal that I got for free. They're the ones that go up the wall (as opposed to on the ceiling) and I had to drill out a couple of existing brackets to get them off. They were too far apart and hung the rails lower from the ceiling than I wanted. the goal is to be able to pull in the car and have the bikes hang high enough that there's enough clearance for them over the hood.
I used 3' sections of slotted angle iron to attach the rails to the rafters. They were about $7 each...probably could have done it cheaper but I gave up and just bought them at Lowe's.
The rollers are garage door rollers from ebay, which were $23 for 20 of them. They have a 4" stem that just slides into the bars. No attachement point necessary.
The bars are sections of .5" conduit. I bought 5 pieces of the 10' length for ~$1.75 each and cut them down to 50" each.
The hardest part were the hooks. I couldn't find S hooks big enough to save my life, online or anywhere else. Now that I spent some much time on them, I'm sure someone will tell me where I can get exactly what I need for super cheap. For them I bought a couple 7' pieces of .25" aluminum strap and a couple pieces of PVC to use as a guide. The aluminum was about $7 each piece and the PVC was less than a dollar for both.
I used some flat plastic tubing to go over the hooks. It fits perfectly and cost about $3.
All in all, it wasn't that expensive, it's very versatile, and it's a big improvement.
You have to heft them up there.
I've been using the "block and tackle" type bike hoists and have been VERY happy with them. They are easy to attach and easier to hoist the bike. Lowered almost to the floor, they also make a decent, impromptu bike work stand.
Quoted: 47 Post(s)
Liked 29 Times
I considered the bike hoists too, but they didn't accomplish what I was looking for. They were more expensive...not a lot, but still more expensive to get 10 of them (I've got 9 bars on it right now with one more not up there). The bigger issue was being able to compact the bikes into a small space. My rafters are 24" apart and I don't think I could have fit the bikes together as closely with the hoists.
True, you do have to actually lift the bike up there, but that's not a problem for me, especially since you can do one wheel at a time. I know back, neck, etc. problems could make it a pain (no pun intended), but I luckily don't have issues with anything like that.
My garage also has 24" rafter spacing. The solution is to mount a board (or metal bar) which spans the bottoms of the rafters, not unlike the L-shaped bracket you have as your base. Hoist spacing is up to you. The hoists are more narrow than the bikes.
Nonetheless, I like your solution, too.
Quoted: 47 Post(s)
Liked 29 Times
I made some more hooks last night and how have 8 hanging up there. Earlier I said I now have 9 bikes, but this morning I realized it's actually 11.
I'm not sure how those other two slipped by me.
Quoted: 47 Post(s)
Liked 29 Times
I'm not sure that's a good explanation, but they just don't tend to run into each other.
Bikes: 1992 Bridgestone RB-T, 1997 KHS Summit X converted to an Xtracycle, 1993 Trek 970 SingleTrack, 1973 Raleigh Grand Prix
Or make a modified version of Brock's roller rack with a hoist hanger attached to each one. Then they are easy to lift, and then slide out of the way.
I was thinking that this would be good in my garage. I could lift them in the open area, and then slide them out of where we walk over above the MG. Then I remembered that the garage door has to go up... The front of my garage has three sets of fluorescent lights, my cord reel, and an air hose reel hanging from the ceiling, as well as the swing down attic door. Not enough room to hang the four bikes.
You should close your discussion of the absence of back and neck problems with the word, "yet".
Steve - Lorain County, Ohio
Xtracycle conversion on 1997 KHS Summit X
Chrome Freak
Bikes: 71 Chrome Paramount P13-9, 73 Opaque Blue Paramount P15, 74 Blue Mink Raleigh Pro, 91 Waterford Paramount, Holland Titanium x2
Liked 26 Times
I like it. Sort of like an upside down vertical file for bikes.
1971 Paramount P-13 Chrome
1973 Paramount P-15 Opaque Blue
1974 Raleigh Professional Blue Mink
1991 Waterford Paramount
Holland Titanium Dura Ace Group
Holland Titanium Ultegra Triple Group
