1 chainring on XC bike
skiptracer
Bikes: Interloc steel with mainly LX stuff, psylo XC
Hi, what's relevant to this forum is that i'm riding an Interloc steel frame with the new LX cranks and an LX front derailieireliereliddurielr.
I just realized that I don't ever used the first (smallest) chainring on my crankset and i never really need between 2-1 and 2-3 and 3-7 and 3-9, so i thought i might try to get some of those classy one chainring DH cranks to simplify things, but lo and behold to do this i'd need to spend nearly 200 bucks. so, i do have a GT speed series BMX, can i use my 3 piece BMX cranks? or does anybody know a super cheap (sub $75) solution for this? know any super cheap DH cranks? thanks.
Bikes: Lots
Agreed, a DH specific crank will weigh a lot more. Plus, your BMX sproket will be too wide to accept an 8 or 9 speed chain.
If you never use the granny gear, remove it and reset you lower limit screw on your front "D E R A I L L U E R". If you find out you don't use the big ring either, you can file the teeth off, or replace it with a bash guard. I would keep the front derailleur on because a chain guide is much more expensive and weighs more than a front derailleur that you already own.
L8R
L8R
"Life is not a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside, thoroughly used up, totally worn out, and loudly proclaiming, "WOW, What a Ride!" - unknown
"Your Bike Sucks" - Sky Yaeger
I got a Spot chainring guard for about $40. Several other companies make them for about the same price. Salsa makes one that looks pretty cool. They come in different sizes, and in 4-bolt or 5-bolt configuration, so there should be one that fits your LX cranks. (My Spot is on a 5-bolt XT crank). You use the middle chainring and bolt the chainring guard where the outer chainring would go. However, I would use a non-shifting single chainring without ramps, like a single speed specific ring. This way, the chain is less likely to fall off. That said, I have never tried mountain biking with this setup (single ring with 8 or 9 cassette). If the chain still tends to fall off, you might have to leave the front derailleur on to keep it in place, as mentioned above.
