Tire pressure?
Bikes: Lots
Well, for overall control and speed, (depending on rider weight) you should keep your tire pressure between 35 and 45 psi. Generally under 40 is best. This will give you a good compromise between traction and control and since you are riding off-road will help you roll over loose soil.
Many people believe that if they overinflate their tires they'll roll faster. Not necessarily true. If the trails are HARDPACK conditions then yes, but if you have any roots or any varied soil conditions less air will be faster. A softer tire will provide grip over roots. Overinflated tires will skate across the tops. In loose soil, a softer tire will allow the wheel to stay on top of the loose stuff by spreading the load. A hard tire will cut through like a knife. A softer tire will absorb rock and roots and give some inherent suspension. A hard tire will bounce like a pinball.
You should experiement. I usually overinflate my tires at the trailhead/truck and then stop every few minutes and "burp" some air (quick little burst) while I'm waiting for friends to regroup. Once I feel my speed increase. Yes, increase! I leave it be. When I get back to the truck, I'll put a gauge on it to verify the pressure. Then next time under similar conditions, I'll start just a few psi above that level.
I'm a big boy, (250 lbs) I need a bit more psi than you skrawny toothpick riders. (really I'm just envious). So I usually start at 50 psi and work down from there!
L8R
L8R
"Life is not a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside, thoroughly used up, totally worn out, and loudly proclaiming, "WOW, What a Ride!" - unknown
"Your Bike Sucks" - Sky Yaeger
Bikes: Lots
How much do you weight Jas? at 80, you're starting WAY too high. Unless you're starting with a 10 mile section of riding on the road to get to the trails.
I'd start at 45 if you weight under 200 lbs.
L8R
L8R
L8R
L8R
I weigh 200lbs, and I do ride the road to the trails which is why I start so high. I cannot stand powersapping. The first section of the trails are also very dense hardpack.
Once I get to the looser/rootier section of the trails I generally bleed down to about 50ish.
Wood Licker
Bikes: Trek Fuel EX 8 27.5 +, 2002 Transition Dirtbag, Kona Roast 2002
50 pounds...thats insane. It really is incredible how different people are with pressures. I run 35 almost all the time. If on skinnies or wet I probably run 25 to 30ish...
Originally Posted by Maelstrom
I can see that. I suppose I do (if I take the time) run higher air pressure to get to the trail.
I think how much pressure you need to run to avoid power-sapping is related to how you pedal.
I'm on the anarobic side of the spectrum, and have very powerful legs. I think the large surges of power with each stroke I feed to the wheels will make the sapping effect worse than someone who spins at a high RPM keeping the pressure very smooth.
Maybe someone has experience with that?
What about say i ride in the city? Traction isn't as important, so I will think higher pressure reduces the contact surface area = less friction. Of course with off-road tires you get more vibration this way.
i pump mine pretty high, too. sometimes i lose traction if i'm on dry loose dirt, but it makes me feel like i've got more control with the added rigidity.
Bikes: Devinci Guzzler, 04 Canadian version
I am 200#s give or take and I agree,I hate loosing enegy on a climb so I keep my rear at appr.45 and front at appr.35.I had a frame that was harder to climb with than the one I ride now so maybe geometry plays a bit too.my setup works well for me overall.
