Trigger shift
Domestic Domestique
Bikes: Brand New Old Catamount! Schwinn Homegrown, Specialized FSR, Salsa Vaya, Salsa Chile Con Crosso
Liked 6 Times
Trigger shift
I have a strange idea. Is there anyone making a left hand trigger shift for the rear derailer? I searched and came up with nothing. It would greatly simplify my life.
Thanks.
Thanks.
Domestic Domestique
Liked 6 Times
My throttle is on the right, so is the rear derailer shifter. I have a single front chainring so if I could shift the rear derailer with my left, I won't have rig up an entirely new throttle.
The closest thing on the market to what you're after would be a rear bar end shifter mounted to a Paul thumbie, mounted upside down on the left bar so it could be manipulated with your left thumb/fingers.
Senoir Membre
Bikes: Centurion Le Mans, Bianchi Sport, Trek 3500
Shift with the hands, throttle with the legs, it simplifies my life.
Twist shifter will solve your "problem". But you would have to twist the other way.
Of course my throttle is also with my legs. Best you ask this on the "other" bike forums other than the Mountain Bike section.
Domestic Domestique
Liked 6 Times
It's a mountain bike. I'm looking for a mountain bike part. I didn't realize I needed to belong to the club before asking questions.
And to that, I add this: take that rod out your @$$.
Te mortuo heres tibi sim?
Bikes: hardtail, squishy, fixed roadie, fixed crosser
AFAIK, no one makes such a part. A thumby, or a twist shifter may work for you.
Or, take a set of the upper level SRAM triggers that have adjustable mount points and see if you can move things around enough to somehow let the rear/right hand side shifter work well for you on the left.
Otherwise, pedal and ditch the throttle bits. It's your bike for sure, but I can't say I get the point of electric assist on a bicycle.
Domestic Domestique
Liked 6 Times
again, just opinion. it's whatever works for you, and if you're out riding a bike/having fun/enjoying it, then that's all that matters.
good on ya either way! a 24 mile pedal commute isn't an easy thing to get yourself to do every day.
