more questions on tactics
Bikes: Giant Defy Pro 2 AXS, Tern Verge D9
Quoted: 15 Post(s)
Liked 11 Times
thanks to knowledge I learned on this board, I have enjoyed TDF more than any previous ones I have casually watched. Now that the tour is over, I am still puzzled over some strategic moves:
1. During the stage where at the end Contador was descending vs the Schleck brothers, the commentators kept saying that Contador failed to drop the Schlecks, instead dropping his own teammate Kloden. I could see on TV that during the ascent, Contador kept looking back hoping Kloden could come back up. Then at the summit he gave up and just rode after the Schlecks all the way. My question is: what could the presence of Kloden get him that he couldn't do by himself during the descent? What's the big deal of "1 vs 2" in a descent? Wouldn't he be riding in the draft of the Schlecks anyway? What difference would Kloden make? What "moves" could they pull if it's "2 vs 2"?
2. During the same stage, towards the end, Contador pat the back of the Schlecks more than a few times (I am assuming he's saying something like 'the win is yours') Is he doing that so that the Schlecks could relax and therefore not out-exhaust one another for no apparent reason? At the very end, Contador pulled in front of Andy Schleck and grabbed 2nd, yet he didn't really challenge Frank for 1st. I suppose there's a tactical reason of grabbing 2nd vs 3rd? Since he conceded the win, I suppose the reason is not a ego thing? Was it because (if he stayed 3rd) Contador did not want Andy Schleck to intentionally create a time gap between 1st and 2nd?
3. During the 2nd to last stage, when Contador was said to hold back the attack in order to "pull" armstrong for him to keep his podium position, how could Contador's "slowing down" help pull Armstrong? After all, Armstrong still had to ride up the ascent by himself? Why does it matter whether one had a teammate closely in front of him or not? I supposed draft was not a factor here? Did Contador's "slowing down" in fact prevent Franck Schleck from widening the gap between him and Armstrong? If so, why?
What the Schlecks could do is to attack alternately, thus tiring AC down. If Kloden was up to the task, he and AC could in turn pull that off against the Schlecks as well - theoretically.
2. Don't think they cared too much about #2 or #3 since they all got the same time. AC probably agreed to let FS take the stage; he's got no beef with AS.
3. Draft is a non-issue on mountains, I think. Maybe AC was to prevent anyone from attacking, or to neutralize it by catching up, thus helping LA. But I didn't really see that happening.
Magnesium Dogmatic
Bikes: Look 585 Ultra, Pinarello Dogma, Pegoretti Duende, Orbea, Cannondale Capo
1) The 2 on 1 was a non issue. Good example of announcers worshiping Lance and tearing down Contador at every chance. Now if the goal was to win the stage then the 2 have a huge advantage over the one. Several things they can do. One attacks and then Cantador either has to work to catch him or lose the stage. If he counters (and in so doing uses as much energy as the original attacker) then the one that did not attack stays on Contadors wheel and the attacker sites up and catches on the back. Reverse positions and repeat (or same attackes 2 times in a row, mix it up just enough Contador does not know who is going next). Problem is on a climb Contador has a burst second to none, so attack and he catches you, perhaps sits on yuor wheel for a second or two and then passes.
If Contador were a poor decender he could have been in trouble, we saw he is at least as good as the Schleks.
2) You nailed it. No time gap. Contador seems ot have been being careful at the finish. Note the stage went to Frank, not Andy. Contenders often let a non-contender have a stage if they have worked. It is very acceptable not to, what makes you enemies is to have a misunderstanding.
3) Drafting does make a difference in the mountians. Not for me, and likely not for you. Remember the drag goes up as the square of the speed. Those guys are going about 3 times as fast as I can (on long uphills, I, less of a joke on the flat, might even be able to hold a freindly wheel on a training ride). That comes out to almost 10 times the wind drag. But on the next to last stage it was entirely different. Huge wind once they were out of the trees. That kicked it from minor advantage to huge advantage (depending on the wind direction vrs. the road at any given point). Actually wind in hte mountian is pretty common. It can end up huge.
Big Blade
It is refreshing to see that an innocent and untainted viewer can see for themselves what the reality is.
The truth is that non of what was reported or announced by the commentators was true. The commentators are paid by Versus to promote absolutely NOTHING BUT Lance Armstrong. If Lance was the one attacking it would have been labeled "stamping his authority on the race" AC doing it was labeled attacking his own team. Like you said yourself, ACs job is to win, and there is no benefit in him waiting for his teammates. They had dropped. Simple as that. Lance was simply not strong enough to keep the pace of the Scleck's attacks. The monkey dropped and that is that. Its not ACs job to wait for a domestique. That is absolutely absurd and idiocity at its highest and purest form.
The podium spot was BS too. Mountains are mountains, the strong men go, the weak drop. there is no tactic behind that.
At the end of the stage, Contador patted Scleck on the back and gave him the stage. This is what gracious mature champions do. Unlike ******s like Lance who want to take everybody's bag of chips and bully all the schoolkids in the playground. AC made friends by doing this. And good for him, Lance was too busy being dropped back to the team car to go over the press release draft of his Radioshack announcement instead of racing. Lance then goes on to sulk like a cry baby becuase the Astana team wasnt there to pace him up climbs, the only way he knows how to win the Tour.
Well too bad for Lance, and Im happy AC gave the stage to the Sclecks. His loyalty to another team was better served tahn his own back-stabbing Astana team mates who were at the Tour just to promote their own goals for next year and not even bother supporting AC for his win.
In fact, I wish Contador had attacked non stop to drop both Kloden and Armstong, they were pretty much on different teams anyway, proven by their announcement of their RadioShack plans.
I hope half the Radioshack team gets busted in the classics races in the beginning of the season.
Bikes: Specialized Tarmac SL2, Specialized Tarmac SL, Giant TCR Composite, Specialized StumpJumper Expert HT
Howzit, I thought you were banned?
Big Blade
Back by popular demand baby. I missed you too.
I tossed and turned night after night just thinking of how we could be once again re-united. And here we are. On the cusp of BF once again rekindling what we once had. Oh, how sweet is this now?
1. I don't think AC needed any help on climbs, really. Kloden helped LA up in Arcalis (?) as LA needed someone to pace him up the climb. AC never really needed it. If anything, his strategy was very simply, to attack, and defend himself. When he defends, he just sticks to the wheel of whoever was attacking, and he's really good at that.
Elitist Troglodyte
Bikes: 03 Raleigh Professional (steel)
1) It wouldn't have affected his placing (i.e. first), but it affected Kloden's placing. It might have happened anyway, but you don't want to have your own teammate cause it.
Secondarily, two riders together are safer than one. If Contador had flatted, Kloden could (and would) have given him his bike.
And tactically, it would have freed AC and AK to break off on their own and put time on the Bros were they able to descend faster.
2. Yes. And in the case of AC, it was also to show the world that he could have won had he wanted to.
3. The draft was very much a factor. There was a 25 kph (mph?) headwind, added to the bike speed could be in the 40 kph range. Plus it is easier (mentally) to follow a pace than to set that pace yourself when your legs feel like they are about to fall off.
Stupidity got us into this mess - why can't it get us out?
- Will Rogers
- Will Rogers
Your observations are astute my friend.
Dang, you are a one trick pony and your trick is getting old.
Bikes: KHS steel SS
Obviously you are a very slow climber. These guys climb in the 10-17 mph range. A draft is of great assistance at those ranges.
pluralis majestatis
Bikes: a DuhRosa
Quoted: 537 Post(s)
unless there is a noticeable head wind, the pace is more psychological than anything.
Bikes: Orbea Diva, Santa Cruz Blur
Birth Certificate, Passport, Marriage License Driver's License and Residency Permit all say I'm a Fred. I guess there's no denying it.
You definitely get drafting benefits at 10-16 mph, although much more so at 16 than 10. Look, I can climb up an 8% grade at over 10mph, they definitely go much faster than that.
Quoted: 15 Post(s)
Liked 11 Times
thanks all for pitching in. I've learned a few more things today. Aside from the tangible benefits of drafting, mechanical failures, etc. how big is the intangible psychological benefit of someone "pulling" you? Obviously I have never raced and I have no idea how the human body/mind reacts when having teammates in front "pulling."
pluralis majestatis
Bikes: a DuhRosa
Quoted: 537 Post(s)
on c1 and hc climbs, using displayed speed data from vs, most were 11-14mph.
contador's RECORD-BREAKING-ASCENT up ~7.5% of verbier was 15.5mph
since he did accelerate and attack in portions of the ascent , he probably hit up to 20 or even slightly beyond for short periods. but many others are way down on that scale on the majority of the climb
and the former issue on drafting. again, in still conditions, as a rec rider im much more sensitive to resistance than pro riders makign 2 3 4x times the power. i barely perceive a thing (2ft gap) below 16mph. to say there is a "great assistance" in drafting at those speeds is a ridiculous notion.
Drafting doesn't magically start having an effect at 20mph, It scales with speed. "greatly affects is going to be subjective but when you are battling for seconds even a few percent is going to be significant. In my experience I can save a good bit of time up a climb drafting in the low teens, so it is not a trivial amount, and even slow club rides still benefit from havng someone pulling and sitting on wheels. I would do an analytical calc but I could not find a clear reference for the affect of drafting on cda.
pan y agua
Quoted: 1447 Post(s)
Liked 724 Times
When Contador was patting Schleck on the back on Ventoux, it was to tell him that Contador was not going to pull through and for Schleck to go right ahead.
Implicitly or explicitly, there was also the understanding that Contador wouldn't pull through, but also wouldn't attack at the line.
You could get lost and die.
You could hit a tree and die.
Bikes: KHS steel SS
pluralis majestatis
Bikes: a DuhRosa
Quoted: 537 Post(s)
Right, wind resistance has exponential relationship. 20 is a nice round number, where there is definitely a an advantage. And in the original post i put 10-16 because around 16/17 is where , as a casual rider , i start to "perceive" an effect.
So while its a subjective claim, and we require said analytics, I contend at typical steep tour climbing speeds (ie 14) drafting produces negligible advantages at best
Not if the group rides 10-16mph
