WD40 mishap
WD40 mishap
seems that I somehow sprayed it on my disc brakes and now they brake only when i press really hard. I
tried and washed them with a degreaser but am not seeing any improvement. what should i do next? help please.
Brake cleaner is available at auto stores.
I'm not one for fawning over bicycles, but I do believe that our bikes communicate with us, and what this bike is saying is, "You're an idiot." BikeSnobNYC
If you ever meet a total scuzzball on a bicycle - Teflon-spray does a bang-up job on the rims & pads. Other than this - be very careful around your brake-pads when working with lubricants.
bm - you want bearings/pivots inside the brake caliper to remain lubed, and you don't want to damage the paint on your bike, so my suggestion would be this:
1) Remove rotors and thoroughly clean them with brake cleaner; when reinstalling, make sure to (a) tighten the bolts *in steps* (b) *in the crisscross pattern* and (c) to the manufacturer's spec torque.
2) (with wheel removed) Remove and discard old pads, install fresh ones.
3) Dispose of your can of WD-40 in a fire!
thank you all for the suggestions. I cannot get new pads at the moment, so i have washed the brakes a few more times and I can see improvement.
@mondoman: with my clumsiness I doubt step 3 would end with satisfaction but rather with 3rd degree burns.
It has no legitimate purpose other than to deceive people into thinking that it's a substitute for all sorts of other, better things.
Often on Fritz
Bikes: Franken-Fritz, Horse-Feathers, Junker
Here here! unless of course you got it super saturated, it should wear off within normal riding. Sure they might squeal like a banshee when you first start braking, but that's only for a little bit. If they don't stop squealing, you might have to replace but I'll bet you won't.
Often on Fritz
I would say within a ride, Basically the contamination will be broken down by the heat generated by the friction of the brake pads contacting the disc. So clean off the excess WD-40 and ride for a bit, it has more to do with how hot you can make the brakes and less to do with duration of ride, though these two things sometimes correlate.
I make stuff up
Bikes: '85 Ritchey Commando, '96 Specialized Sirrus, '06 Surly Cross Check
Wrong on both counts.
The War Department became the Defense Department long before WD-40 came along. WD is short for water displacement.
You really need to get out more.
My bike's better than me!
Bikes: Moots Vamoots, 'Dale T2000, DB Response Comp, '98 G. Fisher HKEK, '89 Panasonic DX-6000, '88 Fisher Montare XT, '83 Nishiki Int'l, '72 MB GR, '75 MB GJ, '77 MB LC, '85 Centurion Ironman, '82 Miyata 710
In addition to displacing water and cleaning pretty effectively, WD-40 IS a lubricant.
Is it the BEST lubricant? No. It's pretty lightweight (read: short-lived).
But ... chemically ... it IS basically equivalent to home brew -- mineral spirits + lubrication.
There's a time and a place for WD. Just learn its limits and stay within them. Use it where you should. Don't use it where you shouldn't.
Let the pads sit in some naphtha-based solvent. I suggest charcoal-lighter fluid. It's cheap, clean, and available all over. This will dissolve the oil in the WD-40. Voila! Now attach the pads and take a ride to check for any continuing problems.
Junkmaster
Bikes: Lemond '05 Alpe d'Huez, Rebuilt in 2020
Bikes: 84 Trek 660 Suntour Superbe; 87 Giant Rincon Shimano XT; 07 Mercian Vincitore Campy Veloce
Don't dispose of the WD-40 in a fire! Just give it away, and don't buy any more. It has no legitimate purpose other than to deceive people into thinking that it's a substitute for all sorts of other, better things. All your bike needs is kerosene for cleaning, regular auto lithium grease for the bearings and regular auto multigrade oil for the chain. Buy anything else and you're just lining somebody's pockets.
I wouldn't use WD40 as chain lube or any other type of lube, but it works really good to disperse water and to clean dirty oil and crud off of stuff like chains and gears, spraying it on wet ignitions disperses the water so that cars can start, chases out water out of things so that A, it won't rust, and B, prepares the surface for a true lubricant. I wouldn't use it to clean your brake pads or disk on you bike, I would use a brake cleaner, it leaves no residue behind and evaporates away completly. If your lucky the pads will clean up, I would try that before buying new pads just to see if cleaning them works. You may need to clean the pads several times since pads can absorb oil then release it over time, but since it not subject to the same high tempertures car pads can reach they shouldn't crack due to the heat and oil, but keep an eye on them to make sure.
Multigrade automotive oil works in a pinch, but it attracks dirt like a magnet thus you would have to clean and relube your chain after every ride. You need a lube on your chain and gears like ProLink or the Finishline Products (not the wax base crap like Pedros or White Lightning because these only last about 60 to 100 miles max before you would have to reapply), these products are a dry lube which means they go on wet but a carrier carries the lube into the chain then evaporates away leaving a dry non wet chain after about 12 hours of waiting.
While lithium grease can work on bearings etc there is different kinds of lithium grease which can make it confusing as to which one to use. I've used Mobil 1 Synthetic grease on my bearings for years with no problems...when I say years I mean years...I have over 150,000 miles on my Trek's Suntour Superbe hubs and crank bearings and still going strong.
Using kerosene or mineral spirits which can work for cleaning along with a brush, but it can be messy so use it slowly as not to splatter it everywhere, plus kerosene is extremily flammable so use extreme caution. I like the little chain cleaning machines like the one that FinishLine Chain cleaning machine (which I think is the best on the market) because it cleans very well and it leaves hardly no mess. Do not use Simple green to clean chains because it will leave water behind unless your willing to bake the chain to evaporate the water.
