snow board for a seat? 1st of many dumb questions
Quoted: 90 Post(s)
Liked 18 Times
hello, i've made a few kind of semi recumbent cruisers (posted a few in the alt bike section) and now i'm thinking about trying full on recumbent. pretty much just to try making something really low. so far i have... well.... a really nice fork (i think. won it off ebay and haven't got it yet), so i'm just kind of looking at designs and working out the idea.
anyway, i've noticed some of the really serious looking recumbents have what looks like a children's snowboard on them for a seat.
i know that's not what it is, but i'm wondering if it's been considered or done. i don't know how it would be softened or melted or whatever (maybe cut and fiberglass back together?) to help reshape it, if it needed altering, but it just looks doable.
what do y'all think? and thanks.
Bikes: Giant OCR2, FCR2, Cypress
https://www.hostelshoppe.com/cgi-bin/...ory=1089843061
This is called a hardshell seat, often made of carbon fiber or fiberglass, with a pad or cover. The link above is one example. These things cost anywhere from $100 to $310. I don't see that much resemblance to a snowboard, but if you do, well good for you. Someone else in another thread thought they looked like a banana. It might be about as easy to make one from a banana as from a snowboard, but I think I would just carve the shape out of styrofoam and then cover it with fiberglass if I couldn't find one to buy.
el padre
Bikes: Rans Stratus, ICE TRike, other assorted
Quoted: 5 Post(s)
If you just want flat surfaces then the board or any board would work. you will want to have padding on whatever to make it more comfortable. Trouble with the board is that you can not have the 'curvy shape' ... ...
I've seen the "hardshell seat" on sale for $60. However, I didn't buy one so I dunno how long you'd have to wait to get one at that price. Because I have a contractor's saw (small portable tablesaw), I made a seatback out of quarter-inch plywood slats (7/8 in. wide) screwed onto wooden ribs at right angles. The three wooden ribs are made of 2x4 cut with a bandsaw in order to get the lumbar curve, and laminated with fiberglass to make them strong. I did this so that the seat back exactly fits my back, and equally supports all parts of it, from my shoulders to my tailbone I laminated it with camping foam from Walmart. The whole seatback weighs about 3#.
If you get a seatback, I'd recommend you get one shaped to exactly fit your back. So when you lean up against it, you are comfortable, and there's no more pressure on your shoulder blades than on the small of your back. At least, if you want to be comfortable riding it for a long time. At the moment, I have a simple seatback that only supports the middle of my back. But I can only pedal for about three hours on it, then I have to dismount because my back hurts too much. That's why I built the larger seatback with wood, fiberglass, and foam.
You can go to a chiropractor's office to get a lumbar cushion. This is a cushion you can put on your car seat to support the small of your back. Maybe you could use this and a board and this cushion to construct a curve that will exactly fit your back. Then you can lay fiberglass onto the cushion to cure, thereby making a lightweight seat. Or you could make a seatback from a two straight pieces of plywood and velcro the cushion onto the junction to support your back uniformly, if you're not so picky about weight.
I had my wooden ribs cut at a cabinet shop because I don't have a bandsaw. Then I leaned up against them to see if they were comfortable. After some more cutting with the saw and smoothing with a Stanley surform wood-shaping tool, they fit my back perfectly.
P.S. You could make your own hardshell seat out of 3mm plywood or sheet aluminum or fiberglass.
I used a skateboard for a seat and cut up a foam/rubber yoga mat for padding. Both seem to work quite well. The nice thing about the skateboard was that it was already curved.
One of the guys over at atomiczombie.com used a snowboard on his build and seems to like it.
