50+ prostatitis BPH MTBer Saddle recomendations
Java
Bikes: hardtail
I use to bike alot in my 40's, and now that I am over 50, I get prostate problems a couple times a year. I like to mtb more than road bike, but I now have a really bad case of prostatitis that has left me with a sore butt. I went to the urologist and he told me to "stay off the bike" because doing that only hurts your prostate more (and he put me on flomax). I have been looking at different saddles (Selle italia, Selle SMP, Specialized), and I was wondering if anyone was an mtber and had the same problem and what type of saddle they use. I do not believe that all of these saddle claims to relieve pressure from the prostate area. I'm 6'0'' and weigh 185 pds, and currently use a Selle Italia Flite Trans-am which is a pretty wide (155 mm), hard saddle with a cut-away in the middle. I have enjoyed this saddle for more than 10 years, and have bought two others because the quality of the seat maker is very good. But, now I'm at a loss as to what to do . . . .give up biking?
Quoted: 12182 Post(s)
Liked 1,490 Times
Time to try saddles.
1) If your bars are lower than the saddle, make them even.
2) There are saddles made for that riding position. I use a B17 Champion Special,
and I also like the SelleAnatomica Titanico.
3) If that doesn't work, the next step is a saddle with springs like the Brooks Flyer.
4) Larger tires make for a cushier ride. I use 32c and next year I may go to 35c.
Have you confirmed that the doctor knows what he is talking about re: cycling impact on Prostatitis? Just a side issue, Flomax can cause hypostatic hypotension (or some such name) - a drop in blood pressure when standing up. I took it and got periodic dizzy spells including two fainting episodes after biking. Apparently, this is not very common with Flomax but... I switched meds but Flomax is better. I would recommend watching for the dizziness symptoms but stick with Flomax unless you have issues.
rebmeM roineS
Quoted: 653 Post(s)
Liked 347 Times
If your main interest is MTB, then I won't mention recumbents.
I use a WTB Rocket V Race on my hybrid and tandem.
feros ferio
Quoted: 1390 Post(s)
Liked 1,322 Times
With the caveat that everyone is different, I second the vote for a Brooks Team Pro saddle, which is what graces my mountain bike. The Sella Anatomica also looks interesting, and the three 50+ pastors on the bamboo-framed www.TourDeRevs.org triple swear by them.
Article in the most recent "Road Bike Action" magazine on this very subject. Proper bike fit is the place to start in resolving your problem(before dropping $$$ on saddles).
Saddle choice is a personal thing and most people would probably need a different saddle on a road bike compared to an MTB. As others have said, a saddle can feel very different if its a couple of mm higher or lower...
personally I am happy with the SMP4Bike from Selle SMP. The channel is better than just a hole for me - I sit forward a lot
I am sure that they aren't the best for absolutely everyone, but I think they need to be on the list of the ones you consider next time you make a change
Time for a change.
Liked 5 Times
I had a radical prostatectomy 8 years ago and if you want pain- Try sitting on a saddle after that.
Saddle comfort is difficult for some of us so a few tips and these will work for everyone.
Make certain you are sitting with the sit bones on the wings of the saddle. This takes most pressure off the Pubic bone that is where most of the pain will be coming from. This will normally require that the saddle is moved forward to get the bones in the right place- and they have to be firmly on the wings. Then drop the nose of the saddle till no pain can be felt on the Pubic bone. This may mean that you are sliding forward on the saddle but try it. If you are slipping forward all the time then the nose is just too low. So elevate the nose- drop the nose till it is comfortable. That may take a while. If necessary- put a pair of Cotton shorts over the slippy lycra till you get it right.
And the Selle Trans Am saddle is the one I use on the Tandem. Lots of sitting on the Tandem and not much chance of getting out of the saddle to relieve pressure. At least on an MTB you do have the chance to take pressure off the Butt by standing.
And the prostate is in a well protected area of the body. Unless you are doing unsavoury things with the saddle-I doubt that sitting on a saddle would be the cause of your problem. An Enlarged prostate that then gets affected by sitting is a better reason.
And stick with the saddle you have. Saddles are expensive and you will take a long time to find the "One" that works. Took me 6 years and was just an updated version of the saddle I was using pre R.P.
Spike Milligan
Spike Milligan
Saw Palmetto
I've been taking Saw Palmeto for the past decade. One capsule a day, non prescription 'NOW' brand; never have any prostate problems, although prior to taking Saw Palmetto, I occasionally had some prostate inflammation and slow urine. There are no side effects, and my doctor knows of my usage. Cycling 10 years, turned 70 last year, and ride a Fi'zi:k Arione Saddle.
Fred at large
First, proper saddle fit in width is the most important thing. If the saddle is too narrow, you will be sitting on the fleshy portion of your anatomy. Try 143mm in width instead of 130mm.
Secondly, for prostatitis you will NEED a saddle with a cutout to relieve any pressure there. There are tons of saddles to choose from and a Brooks is not the answer for everyone.
Third, I suffer from prostatitis on occasion. I use a Specialized Phenom. Cheaper than a Toupe and made for mtn biking. It has more padding than the toupe as well as being stronger in the seat pan (better for us fat fellows). This works for me, YMMV.
Last, take the medicine and listen to your doc. Something you can try as well is a hot soak in the tub with epsom salts after riding. It will reduce the irritation somewhat (and any swelling - NO, NOT that kind) as well as soothe your muscles.
Prostatitis is NOT fun. BPH is probably worse. I would gladly spend money to avoid or reduce the pain and other effects from either.
Bikes: Specialized Roubaix Comp, Specialized Rockhopper Expert, Specialized Sirrus Comp
I do not have a problem with prostatitus; however it was pain to find a confortable saddle. What struck me was that only a few mm's up or downwards the feel the saddle gave could be way different. Fwiw I ride a a sell smp stratos and it's pointed a tiny bit downwards on the front and only 3 mm lower than the toupe which almost felt OK but for the pressure. I also removed 1cm of spacers on the front. It
took a while to find that spot. But worth it.
Bikes: Bridgestone RB-1. Nicely restored
Quoted: 13 Post(s)
Liked 9 Times
One thing that I believe helps a lot, is to find a doctor that is a cyclist. I was fortunate to find one for my PCP. (Keeps his bike in his office!) They are out there.
Why I say this: It seems common that when a cyclist has a health issue, he / she is advised to "Stay off the bike" by the non-cycling doctor. Anyone run into this?
Time for a change.
Liked 5 Times
Considering as she was verging on the Obese- I thought this was a bit out of place. But she did agree that she had made a mistake.
Spike Milligan
Spike Milligan
Bikes: Rivendell Chevoit and a Panasonic 1986 7500 MTB
I have a Brooks Flyer...it has springs.. I sent it to Selle Anatomica and had it cut out.
Java
Bikes: hardtail
I wanted to give everyone a big "thank you" for responding to my post. I find it amazing that there are so many different opinons, and experiences, with saddles. After about a month off the bike, I went back to my Urologist, and he told me I could continue biking, but to get a seat with a cut-away. I ordered the Brooks 17 (with springs in the back -- different model), and tried it out, even though it did not have a cut-away. It is a very nicely made saddle, but I continued to experience sharp pain in the pelvic regions b/t my butt-and-balls. I finally stumbled across what I probably have been having trouble with -- my prudendal nerve. I read-up on the compression of this nerve and how it causes sharp pain in the area that I have had pain ("prudendal nerve entrapment" a/k/a/ "cyclist syndrome"). I researched saddles again, and I came across the "ISM Adamo" web page. I checked out their saddles, and bought one. It took only one ride to realize that, over the past ten years I have been putting too much pressure on this nerve, and it has caused me pain, other than my prostate, and I really needed a "large cut-away" in order to improve this condition and continue biking. For me, this is a happy ending to a long miserable process, but well worth it because biking in my life gives me stability. Without it, I drive my wife crazy.
