Ross Eurotour 3 Speed Selector Cable
I pulled an old Ross Eurotour 3 out of my basement to dust off and sell and the cable is not attached at the handlebar selector. I can't figure out how to re-attach it...any suggestions? See picture. Thanks.
Bikes: 1984 Miyata 310, 1986 Schwinn Sierra, 2011 Jamis Quest, 1980 Peugeot TH8 Tandem, 1992 Performance Parabola, 1987 Ross Mt. Hood, 1988 Schwinn LeTour, 1988 Trek 400T, 1981 Fuji S12-S LTD, 197? FW Evans
Quoted: 531 Post(s)
Liked 1,005 Times
I have one of those shifters, but it is on my daughters bike at college, so I'll do my best from memory. If you take the screw out and remove the cover, you should be able to replace the cable end into the hole in the lever. Watch for the ball and spring that holds the lever in position. On the hub, screw the bell crank onto the axle until it bottoms out, then back it out to align it with the cable, then attach the cable and remove the slack. To adjust the Shimano hub, put the lever in 2, and adjust the cable so that the N is centered in the window in the bell crank.
