Motobecane Brakes Killing My Thumb Joint. Options?...
Lug Princess
Liked 5 Times
My vintage Motobecane mixte is set up as a roadbike, and I have been taking it on 25 mile rides several times a week. It's got drop bars and original Weinmann brakes.
On short rides all was fine, but once I started doing longer rides, the joint between my thumb and forefinger began to hurt as a result of squeezing the brakes. The pain kept building up with each ride, until I simply can no longer press these brakes without excruciating pain in the entire thumb and wrist area. I usually keep my hands on top of the bars and press the "suicide levers". But when I try the drops and squeeze the "normal" brakes, it's not any better, same sort of pain.
We have tried to adjust the brake levers into different positions and to adjust the tension so that they are easier to squeeze, but this has not helped. My husband suggests that the old style brake levers are probably just too harsh for me. He thinks that the only solution is probably to replace them with modern components, or to get a modern bike. I do not want a new bike though; I love my lugged mixte.
Any comments/ suggestions? Is this a problem others have when riding vintage roadbikes, or am I doing something wrong? And what modern brake levers would go with this sort of bike?
Thanks in advance!
Thanks in advance!
don't be so angry
where is your hand resting when you are in the drops. There is a flat, straighter section on the bottom, you should be gripping there. If you have small hands you may be gripping up further in the hook (in order to reach the brakes) which is causing pressure on that part of your hand.
Dropped
Ride the hoods! It could simply be the curve of the bars doesn't agree with your hands, or as your husband suggests, you need a modern lever. They tend to require less force to engage the brakes, in my experience.
Tektro R200a. If your hands are small, the compact version:
https://www.harborcountrybike.com/Pro...R11212&click=2
Or the standard version:
https://aebike.com/page.cfm?action=de...=30&SKU=BR7210
Lug Princess
Liked 5 Times
I have small palms with long fingers. The brakes seem kind of hard to reach no matter where I place them. I also have a pretty weak grip.
Shamefully, I am not a strong enough rider yet to hold the drops in that low flat area the entire time. I come from riding upright relaxed bikes, and am still getting used to the balance and control issues with a road bike. This Motobecane is particularly sporty/responsive, and it took me a while just to be able to balance on it at all, even with the hands on top of the bars.
I will have a look at Tektro R200a -- thanks for the links!
If I own it, I ride it
Quoted: 591 Post(s)
Liked 663 Times
Not knowing how old you are, I am going to say go see a doctor. I am assuming your pain radiates from the point where the thumb attaches to the hand. I have arthritis in the joint where you are describing your pain. While I do not experience what you do, I can relate to your pain. It can be excruciating. I first noticed it when I could no longer snap my fingers. Your pain may be your initial indicator.
Lug Princess
Liked 5 Times
Dropped
But, as I mentioned in my previous post, the Tektros will also give you a third possible resting place for your hands. The more positions the better. I generally can't ride very long on the narrow vintage hoods, but these are very comfortable. However, it is possible they may be too wide for your small palms.
Here's one of my rigs with the high bars:
Bikes: 1986 Alan Record Carbonio, 1985 Vitus Plus Carbone 7, 1984 Peugeot PSV, 1972 Line Seeker, 1986(est.) Medici Aerodynamic (Project), 1985(est.) Peugeot PY10FC
Quoted: 150 Post(s)
Liked 34 Times
Maybe you can find smaller sized levers as they might install on youth, or even child sized bikes, if your hands are that small. Also, try to carry a little bit of your upper body weight on your upper torso so it's not all on your hands. It might take some conditioning on your part to do this, but it's really the only way to get comfortable enough to ride extended stints on the drops. Make sure that your grip on the bars or brake hoods is relaxed (but secure) and not too tight or tense. This will help avoid the strain on your hands further.
BTW, I'd get rid of those "suicide" double levers anyway. Those things do not give you the best leverage and performance for braking in emergency situations and should be eliminated like a bad habit. It is why you do not see these on most bikes anymore.
A visit to a good bike shop should steer you toward the correct brake levers and adjustments to them and your bars to get you comfortable and best performance for braking.
Good luck on the fix!
Chombi
84 Peugeot PSV
Chombi
84 Peugeot PSV
Lug Princess
Liked 5 Times
Here is a picture of mine, where you can see the location of both the brake levers and the suicide levers:
It seems that the brakes on mine are in a similar position to yours, aren't they?
Here is another photo:
I do find it easier to grip those modern brakes that seem to be positioned on top of the handlebars, just over
the drop curves. But it seems impossible to achieve that arrangement using these bars and brake levers -- they are
the wrong shape.
the wrong shape.
missing in action
Quoted: 42 Post(s)
Liked 49 Times
The amount of friction in the cables & housings is a major factor in the force required to brake. If they haven't been replaced recently, try replacing them with a set of "slick" or teflon coated cables and lined housings.
Great looking mixte!!
Bikes: Klein
Those levers appear to be way out there.
I find that resting my hands on the outside top of the bars where the curve of the drop starts to be comfortable. In that position, my palms are on the bars with my fingers wrapped around the bars and my thumbs straight.
Since no one mentioned it, dual pivot brakes would also give you more stopping power. I'm not sure if the fit would be a problem on that frame.
Also, as an alternative to the suicide levers, you might consider the "interupter" style brake levers that fit on the top of the bars. Those actually operate the cables instead of moving the brake levers.
Quoted: 150 Post(s)
Liked 34 Times
I also just noticed from the pics that those levers seem to stick out a bit more forward than normal, Anyway, I think that those levers, sucky suicide levers and all, should just be dumped for better quality ones. That would be a good base to build on to improve your situation.
Chombi
84 Peugeot PSV
Chombi
84 Peugeot PSV
Dolce far niente
Quoted: 20 Post(s)
Liked 17 Times
Combine the in-line levers with a set of the aero levers and new teflon housings. Add dual pivot calipers if they will mount. That will make things a lot easier on you.
"Love is not the dying moan of a distant violin, it’s the triumphant twang of a bedspring."
S. J. Perelman
S. J. Perelman
Bikes: Klein
And, as much as I hate to say it, gel handlebar tape helps. It won't look as nice, but it feel good. You are using padded gloves, right?
Quoted: 591 Post(s)
Liked 663 Times
Not to change the subject, but that is a sweet looking Moto.
Quoted: 443 Post(s)
Liked 27 Times
Interrupter levers with old centerpulls require a lot of grip strength. The Tektro levers and Mafac centerpulls on my Peugeot do, anyway.
Your bars aren't shaped for riding the hoods. Get some Nitto Noodle bars and Tektro aero levers.
Dropped
Now, Cinelli 64s have a steep ramp, but I've done 6+ hours in the saddle on my Centurion, riding mostly the hoods, and I've been okay. My hands do hurt a bit more with this older lever body design, though.
Quoted: 150 Post(s)
Liked 34 Times
What about trying out some "randonneur" bend bars too.
They have a bend the elevates the drop portion of the bars a little and are used by many who finds the drops on regular bars too deep.
Chombi
84 Peugeot PSV
Chombi
84 Peugeot PSV
Quoted: 3464 Post(s)
Liked 2,829 Times
I rode three different bikes this weekend, same brake brand and model.
Before you do anything else, Fresh pads, might also mean fresh holders.
A WORLD of difference, the bike with the fresh pads stopped, the others slowed down.
Unfortunately 34 years is not kind to brake blocks, that was my revelation.
Quoted: 7348 Post(s)
Liked 2,470 Times
It's possible that the reach of the bike is too long for you, i.e. the distance between saddle and handlebars.
Lug Princess
Liked 5 Times
I don't think that's the problem. I even moved the saddle back at some point to make the position more comfortable, and now the distance between the saddle and handlebars is just perfect. The problem seems to be a combination of (1) the distance between the bars and the brake levers, and (2) the difficulty of squeezing those levers. I end up really hooking my thumbs over the handlebars for leverage, and that is probably what did the damage.
