Post pictures of your Hybrid
#5451
Quoted: 44 Post(s)
Thanks. The bag is an RX TrunkBag EX. Here is a link:
TopeakŪ Cycling Accessories ? Products - RX TrunkBag EX
#5452
Bikes: Nishiki Superbe, Marinoni Custom SL, Giant TCR Hybrid, Giant TCR 0 Team, Colnago Dream Plus, Trek 2000, Centurion Ironman Master. Giant Cypress-R CX, Kona Muni-Mula ("Colonel Mustard"), Giant TCR2, Giant Defy Alliance 0, Giant TCR Advanced SL 1 ISP
Giant Cypress-R Rebuild
A very basic Giant Cypress-R frame built up with a Kona Karbon Kross CX fork, a Truvativ Touro compact crank, 105 8-speed STI, and Tektro CX cantis. I switch between Specialized Nimbus EX (700 x 28) touring tires and old IRC Cross Country (700 x 35) knobbies. The only changes made since the pic were to replace the rear brake with a Tektro Mini-V for better heel clearance and to replace the Wellgo clipless pedals with Time ATACs. A great cheap and dirty pocket rocket.
#5453
"Colonel Mustard"
"Colonel Mustard" - a short distance commuter rebuild using a Kona Muni-Mula frame, a rigid Ishiwata fork, single 42T chainring, 8-Speed Grip Shift adapted to a road bar, Specialized Fat Boy (26" x 1.25") slicks, cantis & older Shimano 105 SLR standard (non-aero) brake levers with cables set up Scott-Mathauser style (but better ha ha). For more, see: Roly Q's Bike Project Blog: Project Bike: "COLONEL MUSTARD" (2014-04-05)
#5455
Bikes: 2022 LiteSpeed CHEROHALA CITY, 2019 Canyon Roadlite 9.0 CF LTD, 2015 Giant FastRoad CoMax 1, 2001 Mongoose Pro Triomphe,
Quoted: 129 Post(s)
Liked 84 Times
No, both my wife's and my Giant Escape RX Composites have been upgraded to complete 105 drivetrains. You can read about it here:https://www.bikeforums.net/hybrid-bic...e-owner-s.html
#5456
Ha ha ha ha ha
Bikes: 2004 ORBEA Mitis2 Plus Carbon, 2007 Cannondale Bad Boy Si Disc, 2012 Trek Gary Fisher Collection Marlin WSD 29er Aldi Big Box (Polygon) 650b
Quoted: 8 Post(s)
Liked 11 Times
#5457
Quoted: 5 Post(s)
#5460
Quoted: 44 Post(s)
I think all the track racks have the same width track and the same latch bar. The difference is the length and how they attach to the bike. My bag is not as long as my rack but it works fine.
This is the rack I have, I got rid of the flat steel attachment hardware and made my own from aluminum tubing:
TopeakŪ Cycling Accessories ? Products - Explorer Tubular Rack (w/o Spring)
#5461
Quoted: 129 Post(s)
Liked 84 Times
#5462
Quoted: 44 Post(s)
Or you can just use Bontrager large strut kit #427332 (black) for around $5.00 bucks from a local Trek dealer. That has two black alum posts that will attach to the rack mounts and the topeak rack via a couple of c clips. You can follow the discussion here: https://www.bikeforums.net/hybrid-bic...-question.html
#5463
Quoted: 129 Post(s)
Liked 84 Times
#5464
Ha ha ha ha ha
Quoted: 8 Post(s)
Liked 11 Times
I read your original post as if it was something you thought was unique.
#5465
Bikes: 2017 Surly Troll with XT Drive Train, 2017 Merida Big Nine XT Edition, 2016 Giant Toughroad SLR 2, 1995 Trek 830
Quoted: 1916 Post(s)
Liked 310 Times
Thanks, they are the Planet Bike Full Hybrid. They come with no mud flaps so I added the mud flaps from the Cascadias to add a little bit more coverage.(Dirt cheap from PlanetBike.com) They are much sleeker looking compared to the Cascadias due to the single curved over stay.
Looks impressive alright.
If I am reading Planet Bike's Fender information correctly, it would appear that I have no choice but to use their Cascadia 29er Fenders as it is the only fender they sell that is designed for tyres larger than 38mm.
What size tyres are you running?
#5466
Bikes: Surly Ogre, Transit Rock Creek
I'm running Bontrager H2's in 38mm width which are fairly true to size.
#5469
Ha ha ha ha ha
Quoted: 8 Post(s)
Liked 11 Times
#5470
So I measured the fender with a caliper. The overall outside width is 45.72mm. The edge lip is 1.9mm thick meaning the the inner width of the fender is about 41.91mm. If you tire truly measures 40mm wide at its widest you should be fine. What tire are you running?
#5471
Ha ha ha ha ha
Quoted: 8 Post(s)
Liked 11 Times
#5472
Liked 310 Times
I'm likely to start off with a 38mm sized tyre, but want the option to explore larger sizes to see if they work better for me.
Having said that, with the information you have provided, I could probably quite easily live with 40mm tyres and then be able to run that beautiful fender.
#5473
Bikes: Canyon Endurace
Quoted: 1041 Post(s)
Liked 923 Times
My Trek 7.4fx
I just flipped the stem today and I can't believe how much more comfortable the ride is. Next swap-out will be the red pedals for either a set of Shimano Saints or Crank Bros 5050 //2. Once I wear out the stock 32mm tires I will be moving to a 28mm width. Other than that... maybe a little bling here and there but nothing major. The bike rides great, why change what works?
#5474
Liked 310 Times
Is it just a matter of different lengths, or is the angle dramatically different between the two of them?
#5475
Ha ha ha ha ha
Quoted: 8 Post(s)
Liked 11 Times
Notice his stem is close enough to level, whereas before it would have been angled up a little , maybe 10 deg (?)
You can also often change the height by moving spacers. If you buy a hybrid with the old style quill type stem, you pretty well have to buy a new stem.
