Framesaver really necessary?
I'm looking into purchasing a steel frame that's already built up so the shop wants $50 to treat it. Is Framesaver really needed? Does it make that much of a difference?
Thanks for your input.
Gear Hub fan
Bikes: Civia Hyland Rohloff, Swobo Dixon, Colnago, Univega
Where do you live and what kind of riding will you do?
Many steel frames have lasted for 50+ years without it as long as not exposed to too much salt air and water. Even in climates as wet as England and other areas of Northern Europe the frame is probably the last thing to fail, at least from corrosion.
I certainly do not worry about it where I live, northern Nevada.
Gear Hubs Owned: Rohloff disc brake, SRAM iM9 disc brake, SRAM P5 freewheel, Sachs Torpedo 3 speed freewheel, NuVinci CVT, Shimano Alfine SG S-501, Sturmey Archer S5-2 Alloy. Other: 83 Colnago Super Record, Univega Via De Oro
Visit and join the Yahoo Geared Hub Bikes group for support and links.
https://groups.yahoo.com/group/Geared_hub_bikes/
Great State of Varmint
Liked 15 Times
^^^ +5
I keep my bikes dry and sheltered - usually. My 1982 PUCH Reynold's 531 frame/fork has not been treated with a frame-saver compound. There is not a single patch of rust to be found. But if you live in high-humidity or ride through water - go for it.
Aluminum frames are not susceptible to surface-rust past a single layer of aluminum oxide. And the single layer of aluminum oxide protects the frame (and components) from further oxidation.
Quoted: 2026 Post(s)
Liked 1,096 Times
Yet another integrity test for the LBS at which they seem to be doing badly. If you operated such a shop in an area where this were an issue, wouldn't it be good business to offer this service either free or at a nominal charge, before building the frame up, as a matter of course? As stated, steel bikes have been used here in the rainy north of England for decades without giving this a thought. The seat tube and its access into the bottom bracket is probably the Achiles heel, but I assume your BB bearings are either sealed or sleeved.
Frame Saver isn't essential for bikes ridden and stored in moderate conditions. Annual overhauls should be done to clean and dry out areas where water can gather and a bb shell drain hole should be present and kept clear. I have Frame Saver treated my '83 Trek steel framed "rain bike" but it is used routinely in wet conditions.
Map maker
Bikes: Ventana El Ciclon, Walt Works 29er, Specialized Enduro (fixed up for my son).
I've treated a steel frame before with a spray can of gun oil I got from Wal mart for like 3 bucks. I did it myself BEFORE I built it up. If it has already been built you could probably get away with taking off the stem and seat tube and spraying it in that way. Find all the vent holes and spray it in them. Turn the frame every which way to coat the inside of the tubes you should be good for quite a long time. Be careful of getting a lot of oil down in you BB if it is old style with open bearings. If it is cartridge bearing you should be OK.
Just be careful to wipe all the excess off for a few weeks that will weep out of the vent holes and could drip on braking surfaces like rims.
Framesaver certainly isn't a bad idea for a steel frame. That said, a can of it costs $13 and will treat 3-5 frames. Being charged $50 to treat a frame sounds like a complete rip-off!
Liked 1,096 Times
Thanks for all the replies.
I live in Southern California but intend on using this as a utility bike including rain rides. It's a Surly LHT.
Yes, the $50 dollars includes having to partially dismantle to treat the frame but I need to see if they could order another one and treat it before building it up.
I make stuff up
Bikes: '85 Ritchey Commando, '96 Specialized Sirrus, '06 Surly Cross Check
Framesaver is not really necessary. You've got a heavy duty chromoly frame already. Chromoly is pretty corrosion resistant to begin with. I lived in Huntington Beach for years and never saw steel frame bikes with corrosion damage. Save $50.
Gear Hub fan
Aluminum subjected to salt and water continues to corrode so frame treatment inside is also worthwhile IMO on aluminum frames used near the ocean. Fix any paint chips promptly too. Also a good idea to keep a good layer of wax on any polished aluminum components on any bike used in such conditions, otherwise they can corrode relatively fast and soon look like they have skin cancer.
Quoted: 38 Post(s)
Liked 11 Times
I've lived by the beach my whole life.My 30 year old bike is still fine.
If your going to ride it in the ocean,you might want want to give it a whirl.Either way,can't hurt anything.
Quoted: 443 Post(s)
Liked 27 Times
Do you realize that Reynolds introduced butted 531 bicycle frame tubes in 1935?
Quoted: 3375 Post(s)
Liked 5,514 Times
41xx steel is a family of high-strength low-alloy steels (HSLA), as specified by the Society of Automotive Engineers (SAE). Alloying elements include chromium and molybdenum, and as a result these materials are often referred to as chromoly steel, or cro-mo, or CRMO. They have an excellent strength to weight ratio, are easily welded and are considerably stronger and harder than standard 1020 steel.
While these grades of steel do contain chromium, it is not in great enough quantities to provide the corrosion resistance found in stainless steel.
I make stuff up
Your reference is correct. Stainless steels are more corrosion resistant than HSLA steel. HSLA steels are in turn more corrosion resistant than carbon steels. Corrosion resistance is a continuum. Chromoly is relatively corrosion resistant.
Reference: https://en.wikipedia.org/wiki/HSLA_steel
"HSLA steels are also more resistant to rust than most carbon steels, due to their lack of pearlite."
Quoted: 140 Post(s)
Liked 162 Times
I treat all the steel frames I ride with Framesaver. Then, when I do ride in the rain, it makes me feel more at ease in regard to the possibility of rust damage. The fact that I am more at ease is well worth the few bucks it costs to buy Framesaver and the time and trouble it takes to apply it, even if, in fact, the frame might never actually be damaged by rust, with or without Framesaver.
As for paying someone else to strip a frame and apply Framesaver, I can't relate to that; but if for some reason I couldn't do it myself, I'm sure I would pay $50 for it if it were a frame I care much about.
Gear Hub fan
Another rust inhibitor is LPS 3. It dries to a waxy coating on the surfaces it is applied to. I have not tried it on bike frames but as an interior frame coating I would expect it to work. I have never used framesaver either. What is it's surface like after drying?
Liked 1,096 Times
Another alternative is Amsoil HDMP, which I believe is identical to Frame Saver. I expect Peter Weigel is having the exact same product packaged under his brand name. HDMP is available at many independent auto supply shops and comes in a larger can for less money than Frame Saver.
My 28 yo Columbus SL Davidson only has one spot of rust on it, where the tube was dinged when it was still fairly new. I wouldn't spend money on it, but it wouldn't hurt either.
Quoted: 443 Post(s)
Liked 27 Times
How does the fact that more cheap bikes with thick 1020 tubing have been sold over the years than quality bikes with thin-walled tubing prove that tubing walls have gotten thinner in the last few decades?
My 1959 Carlton takes a 27.2 mm seatpost. That means that the walls are .7 mm thick. Not a lot of modern steel bikes have thinner walls than that. That's five decades.
Liked 1,096 Times
I don't know the answer to that question and I'll bet you don't either. I don't know why they couldn't roll the tubes just as thin back then. The process had been developed about 40 years earlier.
The really thin wall Cr-Mo tubes came out when "oversized" tubing began to replace "standard diameter" steel tubes. This happened as both ultra-high strength heat treated alloys became available and steel tried to compete with Ti and Al for building light frames. Some of these had butted sections with 0.3 or even 0.2 mm wall thicknesses.
